Timer question
Is there some type of timer for switches so I can tell how long a switch was on or off? For instance, I have an issue with a laser trip, where if you break the beam it turns the switch on, and if you move out of the beam it goes off. Some times it reverses it's polarity where the switch says it's on but it's actually off. Like the Http hook is not reporting back to the hubitat with the correct information. Before you tell me there is another option, unless you are going to give me step by step dumbed down instructions on how the newer tasmota works with state, I have tried it and fail and truly over it. The way I thought I would fix this if the this other switch is on but the trip switch hasn't been trip in like 30 seconds, reset the switch's state. Any way to do that?
You could set up a rule that triggers on the switch turning on, then waits 30 seconds and does the reset.
