Hello Again,
I there a way to add a time range as a trigger?
Thank You
Hello Again,
Thank You
I use the begin and end times of my desired range as trigger events for a rule. Here's an example of simple night lighting for my front yard.
Thank You I will try that
Triggers are discrete points in time. So as mentioned above, you could do a start and end time (as those are discrete events), but not a range.
