There seems to be a bug when you try to enter time in settings of any app. It makes every date AM even though PM is selected. This happens any time you change a time entry that's been previously entered. I tried this on different browsers and the behavior is the same.
Here's how to reproduce:
- Use any app that has a "time" field in the preferences (or make one)
- Go to configuration and enter any time as PM.
- Click Done to save the app.
- Go back in and change the time but leave PM selected.
- Go back in
- You will see the time is now AM.
I have discovered that this only happens when you change time and don't use the dropdown to change it to PM (because PM already selected). Basically it will not save as PM if you did not change it to PM during your last edit (even if it's already set to PM). If you change it to AM and then immediately back to PM, it saves as PM correctly.
