Go to Settings/Hub Details, and see if the time is set correctly there.
OK, but the problem is that it won't accept any trigger time for 12:xx am. Always changes it to 1:xx am
My time and date is correct.
So, in your test rule you are able to enter a trigger time of 12:30am?
We will investigate this. Thanks for reporting it. Yes, I can enter 12:30. But my hub didn't just switch from DST to Standard Time, as it is always on Standard Time.
Thanks - now go enjoy your Sunday evening sir.
For what it's worth...
I have a simple lighting rule that runs at sunset and sunrise with no offset that triggered correctly.
Mode manager and an RM4 rule that trigger at sunset with an offset ran an hour early.
Offset before or after?
Ran into the same. Sunrise +10m / Sunset -10m. Looks like the rule fired an hour +/- 10m before what the hub reported as sunrise / sunset times. Of course the condition was still false so no action. Including some logs in case it helps.
-ā-------- Logs
dev:6492019-11-03 15:53:36.198 infoIlluminance: 250
dev:6222019-11-03 15:52:36.479 infoIlluminance: 250
app:1002019-11-03 15:48:00.238 info --> Time between Sunset-10 minutes and Sunrise+10 minutes [false]
app:1002019-11-03 15:48:00.220 infoFront Outside Lights Schedule: Time of Day 15:48
dev:6482019-11-03 15:46:43.602 infoGarage Door was closed
app:8112019-11-03 15:46:43.538 infoGarage Door Virtual Status: Contact Sensor 1 - Double Garage Door contact closed
ā------------- System Events
sunsetTime2019-11-04T22:57:00.000ZAPI2019-11-03 16:58:00.117 CSTsunsettrueAPI2019-11-03 16:58:00.020 CSTsunriseTime2019-11-04T12:56:00.000ZAPI2019-11-03 06:54:00.138 CSTsunrisetrue
-------------- Hub Info
Hubitat ElevationĀ® Platform Version
2.1.5.124
Hardware Version
Rev C-4
Offset 10 minutes before sunset / after sunrise.
every night at 0100.
And this morning (monday) it came on an hour late. ie 0615
My outside lights went off exactly as programmed.....35 min before sunrise. C4 cst
Morning @bravenel.......Strange for sure......this moring i can again set a trigger at 12:05 am and it did not change to 1:05 as it did last night. Plus all my sunrise events are right on time....cst
Without any changes on my part I can confirm that rules are executing as expected today.
