Tiles disappear from my Dashboard
I have dashboard which has a few tiles which have disappeared visually from the dashboard. When you go to the 3 dot menu on another tile it shows the location of the ghost tiles as grey (taken) but I can't see them. Most of the ones I've noticed are variables but it could be other items that I haven't realized yet. I have tried a hub reboot with no luck. Currently running 2.3.5.131 on a C-8.
What do I know, but have you tried hitting the green check mark?
Unfortunately that doesn't fix it either.
It's possible the template for those devices are set to transparent. You can go to template setting under the 3 dots and check the background/icon color
Found the fix. I went into the dashboard on the app and just clicked the done button on the dashboard that had ghosted tiles. They reappeared. This seems to be for only tiles that are variable type and not all the variable type tiles.
