The Tiles are sized different on different pages of my Dashboard and I can’t figure out how to change them.
Normally you can manage this with the following two options, but its related with the grid and screen size
I assume you are talking about a phone vs tablet, or phone vs desktop/laptop?
Those settings highlighted above do control size. I find it best to use a fixed height, in my case I prefer 180, but play with that to find what you like. For width, I prefer to leave it blank to scale to different screen aspect ratios or landscape vs portrait.
I'd add that if you do intend to set them to a fixed width and/or height, consider making the values small enough to provide more fine grained control when creating a tile. E.g. If you create a tile and give it a width or height of 1, the height or width value you set in the screenshots above is applied. If you want to create a smaller tile you cannot, well not easily, I expect there is probably a way with CSS. Equally, as you move up the increments of tile size, the same width or height setting is added on. The smaller the settings you use, the more control you have when adjusting the tiles.
I often have my settings in the screenshots down as low as 20-50, then have tile sizes that may go up to 30 or 40 in width or height settings for the tile.
