Hi, I've installed Tile Master (Parent, Child and driver)
But when I run it, and click the "add new Tile Master child", I get
Error 404
Child app not found for namespace: BPTWorld and name: Tile Master Child
The Page requested could not be found
If you are seeing this screen repeatedly, please contact Support. For assistance, email support@hubitat.com or go to community.hubitat.com .
Any ideas ?
Thanks, Yannick
Something didn't install correctly. Did you follow the instructions on my github?
That usually means the child app isn't installed.
You should be showing 2 files like this under Apps Code
And 1 under Driver Code
Yep, I had the two lines ok and everything installed without errors but somehow something went wrong. I deleted the child and reinstalled and now it works !
Thank-you !
system
Closed
September 23, 2022, 11:24am
4
