THIRDREALITY Smart Garage Door Opener < button controller!
THIRDREALITY Smart Garage Door Opener, Matter Certified, Retrofit with Existing Remote, Compatible with Alexa, Apple Home, Google Home, SmartThings, Home Assistant & Homey
I have one of these, I’m using it as a secondary garage door opener.
It works fairly well, it gets the job done if this is your only option.
I think there is another thread about it here, but I could be misremembering.
The tilt sensor works directly with the opener, you can’t see it in Hubitat, and its not super accurate from my testing.
Does this work directly with Hubitat Matter or are you using a HomePod or something else?
Directly to Hubitat, then shared with Apple Home via the builtin integration.
I don't have any Apple stuff. I decided to skip matter and wire a spare opener circuit board to a Sonoff Mini-ZBD and use the Third Reality garage door position sensor. Working great. Technically off topic but in case anyone is searching for options ...
@Hal3 - I just found this post as I've ordered that Sonoff Mini-ZBD to test. Did it pair ok and what driver are you using for it? I'm in the process of scrapping some of my Fibaro Z Wave devices due to compatibility issues introduced when switching to Z Wave js. I've decided to build up my Zigbee network in favour of Z Wave.
I recently added Home Assistant running in Docker on an old PC converted to Ubuntu Linux to my Hubitat setup. I did this as part of an interest in local voice recognition expecting to eventually move away from Alexa and the Amazon cloud. This is a long way of saying that I used MQTT and Home Assistant rather than Hubitat for this project. I expect that Hubitat will pair with this Sonoff Zigbee device easily. I used Grok 4.6 via Hermes to create the automation. Hermes thoughtfully added my driveway and garage security cams to the automation without me suggesting it. Hermes just saw the camera feeds and added them in autonomously. My only additional cost for this project was the Sonoff dry contact device. $13.41.
