C-8
2.4.2.143
I have a thirdreality motion sensor. I left the house and realized it was stuck in an active state when I left (which blocked my alarm from arming).
The battery on it has always reported 100%
I read other threads on here, tried switching the driver back and forth from Generic Zigbee Motion to the no-temp driver (clicked configure each time I switched), but I keep seeing this in the logs:
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:27:52.713 PM
info
reporting configuration for Power Configuration (cluster 0x0001), attribute 0x0021 failed, unsupported attribute
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:27:51.707 PM
info
reporting configuration for Power Configuration (cluster 0x0001), attribute 0x0020 failed, unsupported attribute
So I enabled debug logging and installed new batteries, and I saw this in the logs:
dev:222025-09-10 11:26:45.769 PM
info
Apt Motion battery is 92%
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:26:45.262 PM
info
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:26:44.506 PM
info
New batteries - but now I'm at 92%, even though it's showing some power configuration error?
Debug logs:
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:29:39.818 PM
debug
descMap:[raw:68B00100010A210020B9, dni:68B0, endpoint:01, cluster:0001, size:0A, attrId:0021, encoding:20, command:01, value:B9, clusterInt:1, attrInt:33]
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:29:39.540 PM
debug
descMap:[raw:68B00100010A2000201D, dni:68B0, endpoint:01, cluster:0001, size:0A, attrId:0020, encoding:20, command:01, value:1D, clusterInt:1, attrInt:32]
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:55.103 PM
debug
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:54.839 PM
info
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:54.836 PM
debug
descMap:[raw:catchall: 0104 0001 01 01 0040 00 68B0 00 00 0000 07 01 86002100, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:68B0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 21, 00]]
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:54.340 PM
debug
descMap:[raw:catchall: 0000 8021 00 00 0040 00 68B0 00 00 0000 00 00 E48C, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:68B0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E4, 8C]]
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:54.089 PM
info
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:54.086 PM
debug
descMap:[raw:catchall: 0104 0001 01 01 0040 00 68B0 00 00 0000 07 01 86002000, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:68B0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 20, 00]]
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:53.571 PM
debug
descMap:[raw:catchall: 0000 8021 00 00 0040 00 68B0 00 00 0000 00 00 E28C, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:68B0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E2, 8C]]
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:51.542 PM
debug
descMap:[raw:catchall: 0104 0500 01 01 0040 00 68B0 00 00 0000 0B 01 0000, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:68B0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:49.525 PM
debug
descMap:[raw:catchall: 0104 0500 01 01 0040 00 68B0 00 00 0000 04 01 00, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:68B0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
[dev:22](http://10.0.1.190/device/list#)2025-09-10 11:28:49.360 PM
warn
configure...
Any ideas?
