Anyone having issue with the thermostat tile? It appears the thermostat tile for my heating devices are changing 0.1 of a deg. for every button push, and no longer control my devices. I get the error like this....
I wish we could change this, as none of my heating devices like the decimal, every button push before was 0.5 deg and that gave me a little trouble, but two quick pushes solved it. It would be nice if it was a whole degree in my case.
I have to admit the issue is my fault. Just today I posted how well my system was running and the lack of issues. As I wrote the post the thought at it precipitate an issue crossed my mind but I went ahead with the post anyway. Next time I'll remember
Hmmm interesting. Is your tile now in 0.1 increments like mine? That has changed recently. I am using the built in Remotec ZXT-600 driver. I also have issue with an external driver for my StelPro Ki Heaters.
That's good news, thanks! A question though, is it possible to be able to choose the increments you need? Even 0.5 deg C messes with my heat pumps, as they only take 1 deg increments. Pretty sure my StelPro Ki heaters are the same. Possible to have two tile choices for increments? Never hurts to ask!
Using the Average Temp app setting a Virtual Thermostat device in Fahrenheit. Getting the following error when attempting to set the thermostat tile temperature up or down with 2.2.8.138 on a C-4 Hub. Worked fine in 2.2.7 and older.
This is through android app dashboard. I have tried through browser,, same problem after clearing cache.
Only cool mode changes temperature from the tile. Only cool mode increments in 1 degree c as I set. Heat mode still increments 0.1 and temp value didn't change on device pages nor change the ac unit from the tile.
I see a device in my logs and an app.
Device shows an error. The app doesnt show any logs for any of the heat mode temp changes, only the cool mode changes.
With this configuration setting, will it be per thermostat device, and will it be open to updates by custom drivers, e.g. as an attribute in the capability definition? I am keen to read the value for this in from the thermostat API I am developing with, rather than requiring user intervention. Not wanting to press you for the details, just interested to know if this will be possible or not.
