Thermostat TH112xZB with energy meter - Error every hour
I’m seeing the following error every hour with the “Thermostat TH112xZB with energy merter“ driver on one of my thermostats - I feel like this is something I’ve seen before… Is anyone seeing the same?
@samuel.c.auclair, any idea if there is something I might be doing to cause this? Could it be because no energy was used by this thermostat - seems that might have been the issue before…. I’ll turn it on for a bit and report back tomorrow.
Sorry to not have seen your message before. Do you have more than one thermostat and are they happening for all of them if you have more than one?
Can you tried to only click configure if not already done?
Lastly, do you have the most updated version installed with HPM.
Thanks!
No worries! I am seeing this on multiple thermostats. I just updated to the latest driver manually yesterday, but I just matched it up and updated. I did press configure on this one, but will try again on it and others and report back tomorrow.
Thanks!
