Thermostat Scheduler command to thermostat after release of restrictions?
Is there any way to get the Thermostat Scheduler to send a setpoint command to the thermostat commanding the current temp once the app has been released from Restricted? It seems that when the restriction is released, the thermostat is turned back on, but uses the setpoints which were in existence when the restriction was imposed. Am I missing something?
in Rule Machine the action would be...
More info here
Took me a while to read through the previous thread, but finally got it to work. Thanks for the tip. Am a little surprised that there isn't a check box in the app itself to select whether it returns to previously established settings, or whether it goes to the settings for the then current time.
