Thermostat Scheduler 2.2.5 bug?
Haven't had this issue before but returning from Away mode to Day the thermostat setpoint didn't return to normal and if I switch to Away mode again the thermostat setpoint keeps dropping by the EcoMode Offset amount and never returns to the normal heating setpoint. Found this error in the logs for Thermostat Scheduler
app:2292021-01-27 09:24:56.027 am errorjava.lang.NullPointerException: Cannot get property 'currentHeatingSetpoint' on null object on line 1011 (ecoHandler)
Just updated to the 2.2.5.120 and it is still doing the same thing.
Issue still exists after 2.2.5.125, I also uninstalled Thermostat Scheduler and reinstalled.
@support_team Still have this issue with 2.2.5.127, I submitted a ticket but haven't heard back and know that you guys were having some issue with your email system so figured i would tag you on this. I just setup a Virtual Thermostat just to make sure it wasnt something with my current thermostat and get the same error in the logs.
Noted, looking at it.
Thank you
