Thermostat CT-50 using setpoint
I have the CT-50 and have it hooked up Z-Wave with the generic Z-Wave driver.
I only use Hibitat to make adjustments right now. I do not have it doing full control. I used the scheduler on thermostat right now for it.
When I use the heating or cooling
Setpoint it seems I can only control the thermostat from hubitat. If I change it via the thermostat app it seems hubitat takes it back over and just resets it. So none of my schedules run. This happens until I turn thermostat off and then back on then it regains control.
Any ideas?
try the Radio Thermostat CT101 driver.
Wow didn’t even notice the built in driver. That seems to have taken care of the issue. Thanks!
