Thermostat controller - feature request
When the demand for cooling has been met, the controlled thermostat's cooling setpoint will be set well above the current temperature, thus forcing it to idle, and again using the Control Offset.
Would it be possible to make a feature request? I would like to have this app optional set the controlled thermostat off rather to the idle position. Allowing me to drive an air conditioner with a thermostat 'like' controller.
We plan to add this feature in the next release. Thanks for the suggestion.
thank you ! :smiley:
While you are in there, here is a minor cosmetic issue I noticed while setting it up. Left over from copy/paste from the scheduler app I guess?
Thanks!
