Since the new update last night which had "bug fixes to Thermostat Controller" in the change log, I have errors in my logs and thermostats not working.
I am using the Zen thermostat to control my A/C unit.
The Thermostat Controller controls the Zen.
User symptom: A/C units did not kick in this afternoon (its summer here).
Apps>Thermostat Controller doesn't show the usual page, only shows:
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: Cannot invoke method minus() on null object
In the logs for the Thermostat Controller, at 'random' intervals:
app:7372021-02-04 20:53:53.617 errorjava.lang.NullPointerException: Cannot invoke method contains() on null object on line 554 (thermHandler)
I am using the Remotec ZXT-600 built in driver. The app reinstalled normally but when I selected my thermostat I could not get back to the App. I have read in another thread here it may have to do with a line in the driver not configured properly and the App can't get the information it needs. I can't add the necessary line because it is a built in driver...
Thermostat controller with same issue:
Error: Cannot invoke method capitalize() on null object
and Unexpected error opening the app. (version 2.2.5.131). I got the same error on 3 different Thermostat (Thermostat has built in driver).
Hi @bravenel, i had to remove the Thermostat Controller instances from my hub. The null errors in the logs referred to by others in this thread contributed to this decision, and more significantly for me for some reason the Thermostat Controller app was sending 'null' commands to my A/C units instead of sending 'off', which of course left them running when they should be off, and generated more errors in the logs. so to keep sanity in the household they had to be removed for now. if you like i can re-add an instance for some specific testing, but in the absence of active troubleshooting i had to stop the complaints from the missus...
OK, but I really need more details. The error on line 163 reported above was specific to that driver, which I believe has been fixed (it wasn't reporting thermostatOperatingState). The error in the original post on line 554 has been fixed, and is due for release in 2.2.6.
So, what thermostat are you using, and what error were you seeing. I hope you realize that we can only push out releases with bug fixes on a schedule with many moving parts. 2.2.6 is due out shortly and these problems are most likely fixed.
