I have a Samsung M5 in the Kitchen I send speech to...It looks like to use the Echo Speaks app I need a local server or pay for an online account.
Is there a relatively low end ($) device that works well with Hubitat like the M5 does...but cheaper. I don't want to do anything but announcements, so I don't need music etc. I would prefer wireless over hardware.
The Samsung Radiant R1 (WAM1500) is still available on e-bay and the like for around $50. I have three of them and they work well most of the time. Usually, the only issues I have are after power outages. I have a rule to clear their queue's an refresh all of them at once after outages.
I think it is worth the time. I just put the server on a Rasp. PI3 I already had laying around. Takes no time at all if you just copy paste the instructions. I used the non-docker method.
It is all the other features that you get with Echo Speaks - like voiceCommandAsText, which means Hubitat can just tell Alexa to do anything (even control complex devices connected to Alexa) by just building a string to send as if you were speaking to an Echo directly.
If you can find an IKEA Symfonisk speaker (actually made by Sonos), it works perfectly with Hubitat’s built-in Sonos integration as well as the built-in Text to Speech engine.
You may want to do a search for Hubvoice. You can use a few devices with it like the Home Assistant Voice Assistant preview eddition. It is 100% local as well.
I got a bunch of the Ikea Symfonisk ones and they have been amazing for my needs (I have them all over the house and send various sound effects, pre-recorded sentences, and TTS to them--I don't really use them for tunes).
The Ikea ones also work great as a small shelf (with the wall mount holding them up horizontally).
Before, I was using the Google Home speakers, etc.--but they were rather wonky at times.
[quote="rob9, post:7, topic:163452"]
THANKS!
Ikea Symfonisk
I'm not really up on this product line. It looks like most of the lower end ones are Bluetooth only? Do you have a model number of yours by any chance?...a lot that look like they might be IP based are now unavailable on the IKEA site right now.
Looks like Sonos has a relatively inexpensive ($189) WiFi speaker that will probably work. Not exactly cheap, but not horrendous. When the IKEA Symfonisk bookshelf speakers first came out, I think they were ~$99. It was a great deal at the time. But, that was many years ago.
