Temporarily disabling devices request
Is there anyway for Hubitat to add a feature to temporarily disable (disconnect or block from the hub) a selected device without having to remove it and add it back?
example
In my case I am testing which devices work as router/repeaters for Xiaomi devices by only having one repeater device on at a time it makes it easier to direct the Xiaomi devices to go through them of course they may still connect directly to the hub but once they are routed through the repeater device you could easily disable the router device to confirm it was routed through it as the Xiaomi device would stop working.
It would also make it easier to network devices through a desired router/repeater to have maximum range.
I have installed a smart outlet to my exterior Christmas lights plug (to extend my Zigbee range) which is hardwired to a regular switch inside. So I can kill power to the smart outlet and test how my Xiaomi devices routed through it work with it.
But this is only one location and I don’t want to climb a ladder and wire in different types or brands of devices just to test how well they work to isolate which one is giving me a problem.
As a possible workaround, you could write down the device network id, change it then save, and the device should become unresponsive. How long that’d take to actually disconnect the device from the mesh, I don’t know.
