New to Hubitat. Received my new unit, connected to two Sinope thermostats, and two Sonoff temperature/humidity sensors. In the Hubitat localization settings, I've set my "Temp Scale" to Celcius. My location is set correctly (in Canada). However, I continue to see Fahrenheit for all my devices in the Hubitat web interface.
I've updated to the latest firmware, and I've tried rebooting the hub. What am I missing?
After a lot of messing around, I have it working. I can't say exactly what I did. Was forcing save/reload of device record by changing name/label and saving and it seemed to work for one. The other seemed to change to C when I clicked the "Configure" tile at the top of the devices page for a sensor (not sure what that is/does).
The last device was stubborn. Wouldn't change like other devices. I deleted the device and re-added it. That corrected it.
Could it be you need to refresh your thermostat, following the change in scale? Sounds like that could have been it, needed to initiate a process that recorded the temp in the updated scale.
I had a similar problem with a sensor. I'm on 2.3.6.146, all I had to do was go to the hub settings and there Temp Scale box where you can select C/F. As soon as I did that and opened the dashboard the temp was correct.
