Hi, I am starting to automate my pool with a Qubino Flush 2 relay Temp sensor. The sensor's cable is only 1 meter long (39 inches). Is it possible to increase the length of the cable to around 20-25 feet without issue? Is there another compatible 3-wire sensor already 20-25 ft that wound fit? If I can increase cable length, what is the wire type to do it? Thanks..Yvan
I would suggest reaching out to Qubino support:
