Hi all,
I am trying to cook up a rule for a temp sensor to control an outlet with a heating pad hooked up to it. This is to heat a cat house. The heating pad is old school and doesn't turn off automatically so i originally had a rule through TPlink to turn it on at night and off during the day. I am migrating everything over to Hubitat. I just want something like: If temperature drops below 40 degrees (temp sensor is in cat house btw). then turn on outlet. If not, or if above 40, don't turn outlet on or turn it off. Might anyone be so kind to walk me through it/create one for me as I am still learning. my first attempt does not seem like it will work. Thank you in advance.
