I generally use Temperature Triggers Events with a Periodic Trigger Event just in case, but I decided to remove the Periodic Trigger Event as I didn't think it was necessary. I found out quickly that it is VERY necessary.
Here's my Trigger Event:
Temperature of Greta's Room Sensor reports >= 70.0
Temperature of Greta's Room Sensor reports <= mintemp(68)
And here's what happened last night:
temperature 95.48 °F Greta's Room Sensor: temperature is 95.48°F DEVICE 2021-02-09 05:00:54.036 AM EST
temperature 94.79 °F Greta's Room Sensor: temperature is 94.79°F DEVICE 2021-02-09 04:57:49.793 AM EST
temperature 93.67 °F Greta's Room Sensor: temperature is 93.67°F DEVICE 2021-02-09 04:51:46.894 AM EST
temperature 92.40 °F Greta's Room Sensor: temperature is 92.40°F DEVICE 2021-02-09 04:45:46.432 AM EST
temperature 91.57 °F Greta's Room Sensor: temperature is 91.57°F DEVICE 2021-02-09 04:42:41.256 AM EST
temperature 90.93 °F Greta's Room Sensor: temperature is 90.93°F DEVICE 2021-02-09 04:39:41.977 AM EST
temperature 89.40 °F Greta's Room Sensor: temperature is 89.40°F DEVICE 2021-02-09 04:33:38.758 AM EST
temperature 83.17 °F Greta's Room Sensor: temperature is 83.17°F DEVICE 2021-02-09 04:18:08.834 AM EST
temperature 81.22 °F Greta's Room Sensor: temperature is 81.22°F DEVICE 2021-02-09 04:15:02.462 AM EST
temperature 78.81 °F Greta's Room Sensor: temperature is 78.81°F DEVICE 2021-02-09 04:11:59.326 AM EST
temperature 75.68 °F Greta's Room Sensor: temperature is 75.68°F DEVICE 2021-02-09 04:08:57.877 AM EST
temperature 68.28 °F Greta's Room Sensor: temperature is 68.28°F DEVICE 2021-02-09 04:02:43.041 AM EST
The sensor was obviously reporting the temperatures, why did the Trigger Event not happen?
