Hello, does anyone know of a way to check if a telnet connection is still active when issuing a hub command as such? I'm aware of telnetStatus() receiving the status, but this method is invoked after the fact... I would like to catch if the following command fails synchronously. Anyone?
return new hubitat.device.HubAction("${msg}\n", hubitat.device.Protocol.TELNET )
I don’t believe you can because the command itself is sent asynchronously. Basically it’s in a queue and it won’t fail until that queue executes. So it doesn’t fail synchronously.
