Tapo T110 Integration
I got a Tapo T110 contact sensor for my door, I have no Tapo or Kasa hubs so the sensor cant be set up in the Tapo app. Is it possible to connect the sensor directly to my Hubitat hub? Any help is appreciated, thanks!
No. You need the Tapo hub. AFAIK, this sensor uses a proprietary protocol to communicate with the Tapo hub.
For it to work using the Community App, you need the Tapo H100 hub. The H200/H500 do not work.
