Switching lights with buttons on remote
Hello,
I have several dimmers that I want to control with a ZEN37 wall remote. I'm using the Room Lighting app and was able to set up 3 different scenes that have the dimmers set to different values. I have the activation set to occur when a certain button on the remote is pressed.
It is working halfway the way I want. When I push button 1 it turns on the lights but when I push button 2 I would expect it would switch to scene 2 but instead it turns all the lights off. I have to push button 2 again in order to switch to scene 2.
My goal is to switch the scenes with the different buttons and ideally to turn the lights off I could push the same button for the scene that is currently active. If that isn't possible I could just designate one of the buttons to be an off button.
I suspect that I may need to set something in the means to turn off lights section, but I'm not sure what to set that to. When I look at the apps list I can see that multiple of my lighting scenes are active at the same time and I suspect that may be an issue. Really only one should be active at a time
Thanks.
