After reading most of everyone feedbacks. Look like Zwave is out due to sending off/on command to every switches on the mesh
So that leave Lutron or Zigbee switches it seems
To be fair, I don't think Lutron supports that natively either (though it's likely repeated commands sent over the LAN would fare better than Z-Wave given the higher bandwidth and general reliability of Lutron), nor do any Zigbee switches I'm aware of (and unlike Z-Wave, Hubitat's drivers don't even try to fake it here; not sure why the difference). Many Zigbee bulbs do to some extent, but those come with their own concerns.
But in 12 years will Zigbee even be a thing?
I get it. Like I said, it isn't really your use case. I actually use both a switch and a smart bulb so I end up paying double for each device. That's just the way I'm designing my system.
Consumer Caseta does not support flashing lights. RadioRa 2 does. Not sure if "select" does but I know RR2 does.
Reality check. There are 2 controllers on the market today that have "good" ZigBee support for consumer switches. SmartThings and Hubitat. The consumer ZigBee switches.. oh not many.. Jasco/GE, Soon Sinope... umm... not much to choose from. Probably a few others I'm not aware of a simple google search didn't really come up with many choices. PRO grade Zigbee switching would be Control4. Great stuff but expensive. I know a dealer if interested.
Lutron has been around forever almost literally.... Lutron INVENTED the Dimmer. RadioRa 2 is compatible with ALL controllers worth using and if the controller doesn't support Lutron just walk way. Downside to Lutron RR2... it's expensive upfront. BUT... you'll never have to replace it if you don't want to. It will work and just keep working. Lutron customer service and warranty is the best in the business.
@jeubanks
Thanks for pointing out about the RR2 so I went and read up on about it. Ouch ... the prices LOL plus I would have to take classes to be able to program it! It probably an easy class but still I am sure they charge money for the classes and the dealer software to program it.
I think RR2 and RR2 select will be out of our price range however with the Caseta supporting 75 devices now and if it can at least just blink the light only one time (off then back on) it may be good enough for us to alert an event have occurred then we would probably look at tablet or our phone to see what triggered the event.
Other thought is that I thought I saw a strobe light that use zwave or zigbee online somewhere which could work for our bedroom for fire / co2 / burglar alarm to wake us up when those 3 "serious" events are triggered. I will need to search on this again.
What you all think about just a one time blink home lighting for normal event? Is that doable with Zigbee or Lutron Caseta?
I am going to laugh we have visitor over and they think we keep getting a 1 second blackout every time doorbell rings .
Entry fee is steep but well worth it over time and one of the few "smart" home improvements that actually increase a home value. The "Essentials" class is a couple hours long. It's all online and it's free. You won't need to take the "Inclusive" unless you become a dealer and or just want to play with the higher end stuff or have multiple main repeaters supporting 200 devices.
If you go the Caseta route remember 2 things.
Don't get caught up on the end point needing to be z-wave or zigbee. If what you want is a strobe light then get a strobe light and then determine the control for it. Find one or multiple 12V strobes that you want to wire up and then use a z-wave or zigbee relay to turn them on/off with. There's hundreds of 12V zigbee light control modules out there!
Excellent point about the strobe light! and I also just had a thought
There are 115v strobe light so maybe a zigbee outlet adapter and plug a strobe light into it so i can mount the strobe light on wall and aim it toward to our bed.
We used to have one of those plug in wall strobe light connected to a dial timer that plugs into an outlet. When that strobe light goes off .. there no ignoring it forcing us have to get out of bed to turn that damn thing off.
And yes I read about the "Pro" is a must if wanted to use with Hubitat but thank for the reminder!
I haven't read through the whole thread, but definitely Lutron for buttons. They are rock solid. They're the only thing I've never had even the slightest problem with.
Unless you want color (which in your case, would probably be very helpful, to encode different alerts), then stay with smart dimmers/switches, and use dumb bulbs, to get almost absolute guarantee of lights responding.
With color smart bulbs, I use Hue. It's pretty damn good... for my needs. One issue I have is that when a request is sent, it's the hub that will respond, even if the bulbs don't. So if I try to turn a light on (eg using a remote, a schedule, contact sensor trigger, etc.), and Hue gets the request, the light will show on. Using individual direct-connected bulbs would probably be less reliable, and yet you could get/build automations that check and re-check for failures. (but I haven't used direct-connected bulbs, so I'm guessing.)
We plan to use color bulbs on a lamp stand in some area of the house.
Our goal hopefully if we can make it to work like this is to set up that when there is an event example a doorbell pressed then whole house lighting will blink only once and return to the last state it was in. And the color bulb will come on with yellow color so we know it was the doorbell that cause the whole house to blink. Same if the fire alarm went off then whole house will keep blinking off and on for a minute and at same time the color bulb will turn red so we know what triggered the event without having to find a tablet or pull out our phone to see what triggered it.
That what we hope to be able to set it up this way.
I've got an app that did that, but the wife hated it, so we changed to voice alerts (which I hate) and I deprecated the code. But not difficult at all to do. In your case, the flashing lights are the sole notification system, where for most of us it's just a backup/alternate. So the challenge will be to approach 100% reliability. If the lights are off and it turns it on for an alert, it should wait to make sure it responds and otherwise retry (repeat), and change the color and/or brightness with yet more checks and retries.
I would think that's doable through the Rule Machine. I don't use it, so don't know for sure. I'd bet there are user-built apps that would also do it, though finding one that checks and rechecks device response might be rare or non-existent. My app does it, so if you can't find anything else, lemme know, and I'll re-add flash notifications or build another child-app.
Talking about door bell notifications is one thing. Now you're talking about fire and safety issues. With that I don't want to discourage you from Hubitat however I would strongly suggest you DO NOT use Hubitat or any other DIY automation system for anything safety related especially like fire alarms and alerting.
