Switchbot Presence Sensor P1 - Driver
Created this Switchbot P1 sensor driver for hubitat using our AI overlords (chatGPT Codex). No idea how it works, but it does. I tested it with my own P1 sensor.
It requires the Open Token as well as the Secret Key from Switchbot open API.
The drivers are based off of ToffeHoff API-Bot work here.
 * SwitchBot P1 Presence Sensor driver for Hubitat
 * Maps SwitchBot Cloud API / webhook presence state into Hubitat MotionSensor
 * and PresenceSensor capabilities so webCoRE can use either event style.
metadata
    definition(
        name: "SwitchBot P1 Presence Sensor",
        namespace: "joelrodz",
        author: "joelrodz / Codex",
        importUrl: ""
        capability "Battery"
        capability "Initialize"
        capability "MotionSensor"
        capability "Polling"
        capability "PresenceSensor"
        capability "Refresh"
        capability "Sensor"
        attribute "apiStatus", "string"
        attribute "batteryApiValue", "number"
        attribute "batteryRange", "string"
        attribute "detectionState", "string"
        attribute "hubDeviceId", "string"
        attribute "lastUpdated", "string"
        attribute "lightLevel", "number"
        attribute "switchbotDeviceType", "string"
        attribute "version", "string"
        command "autoConfigurePresenceSensor"
        command "listSwitchBotDevices"
        command "parseSwitchBotEvent", [[
            name: "SwitchBot event/status JSON",
            type: "STRING",
            description: "Optional: paste a SwitchBot webhook or status JSON payload for testing."
    preferences
        section("SwitchBot Cloud API")
            input name: "openToken", type: "password", title: "Open Token", required: true
            input name: "secretKey", type: "password", title: "Secret Key (API v1.1)", required: false
            input name: "switchbotDeviceId", type: "text", title: "SwitchBot Presence Sensor Device ID", required: false
            input name: "presenceSensorName", type: "text", title: "Presence Sensor Name Filter (optional, for auto-detect)", required: false
        section("Polling")
            input name: "pollIntervalSeconds", type: "enum", title: "Polling interval", required: true,
                defaultValue: "60",
                options: [
                    "0": "Disabled",
                    "30": "30 seconds",
                    "60": "1 minute",
                    "120": "2 minutes",
                    "300": "5 minutes",
                    "600": "10 minutes"
        section("Logging")
            input name: "debugLogging", type: "bool", title: "Enable debug logging", defaultValue: true, required: false
def installed()
    initialize()
def updated()
    initialize()
def initialize()
    unschedule()
    updateDataValue("driverVersion", "0.1.0")
    updateDataValue("switchbotDeviceId", cleanSetting("switchbotDeviceId"))
    if(cleanSetting("openToken") && !cleanSetting("switchbotDeviceId"))
        autoConfigurePresenceSensor()
    else
        refresh()
    scheduleNextPoll()
def autoConfigurePresenceSensor()
    if(!cleanSetting("openToken"))
        log.warn "Open Token is required before auto-detect can run."
        sendEvent(name: "apiStatus", value: "missingToken")
        return
    try
        def devices = fetchSwitchBotDevices(false)
        def candidates = devices.findAll { isPresenceDevice(it) }
        def nameFilter = cleanSetting("presenceSensorName")
        if(nameFilter)
            candidates = candidates.findAll
            { dev ->
                dev.deviceName?.toString()?.toLowerCase()?.contains(nameFilter.toLowerCase())
        if(candidates.size() == 1)
            def selected = candidates[0]
            def selectedId = selected.deviceId?.toString()
            device.updateSetting("switchbotDeviceId", [value: selectedId, type: "text"])
            updateDataValue("switchbotDeviceId", selectedId)
            sendEvent(name: "switchbotDeviceType", value: selected.deviceType?.toString())
            if(selected.hubDeviceId != null) { sendEvent(name: "hubDeviceId", value: selected.hubDeviceId.toString()) }
            log.info "Auto-configured SwitchBot P1 Presence Sensor: name='${selected.deviceName}', id='${selectedId}', hub='${selected.hubDeviceId}'"
            sendEvent(name: "apiStatus", value: "ok")
            refresh()
            return
        if(candidates.size() == 0)
            log.warn "No SwitchBot Presence Sensor devices were found. Confirm the P1 is visible in SwitchBot Cloud and cloud service is enabled."
            sendEvent(name: "apiStatus", value: "autoDetectNone")
            listSwitchBotDevices()
            return
        log.warn "Multiple SwitchBot Presence Sensor devices found. Set Presence Sensor Name Filter or paste one of these IDs into SwitchBot Presence Sensor Device ID:"
        candidates.each
        { dev ->
            log.warn "Presence candidate: name='${dev.deviceName}', id='${dev.deviceId}', hub='${dev.hubDeviceId}', cloud='${dev.enableCloudService}'"
        sendEvent(name: "apiStatus", value: "autoDetectMultiple")
    catch(Exception e)
        log.warn "SwitchBot presence auto-detect failed: ${e.message}"
        sendEvent(name: "apiStatus", value: "error")
def listSwitchBotDevices()
        log.warn "Open Token is required before listing SwitchBot devices."
        return
    try
        def devices = fetchSwitchBotDevices(true)
        if(!devices)
            log.warn "SwitchBot device list was empty."
            sendEvent(name: "apiStatus", value: "emptyResponse")
            return
        devices.each
        { dev ->
            log.info "SwitchBot device: name='${dev.deviceName}', type='${dev.deviceType}', id='${dev.deviceId}', hub='${dev.hubDeviceId}', cloud='${dev.enableCloudService}'"
    catch(Exception e)
        log.warn "SwitchBot device list failed: ${e.message}"
def fetchSwitchBotDevices(logRawResponse)
    def params = genParamsMain("devices")
    def devices = []
    logDebug("GET ${params.uri}")
    httpGet(params)
    { resp ->
        if(!resp?.data)
            return
        if(logRawResponse)
            log.info "SwitchBot devices response: ${resp.data}"
        def deviceList = resp.data?.body?.deviceList
        if(deviceList instanceof List)
            devices = deviceList
    return devices
def isPresenceDevice(dev)
    def deviceType = dev?.deviceType?.toString()
    return ["Presence Sensor", "WoPresence"].contains(deviceType)
def poll()
    refresh()
    scheduleNextPoll()
def refresh()
    if(!hasRequiredSettings())
        sendEvent(name: "apiStatus", value: cleanSetting("openToken") ? "missingDeviceId" : "missingSettings")
        return
    try
        def params = genParamsMain("devices/${cleanSetting('switchbotDeviceId')}/status")
        httpGet(params)
        { resp ->
            if(!resp)
                return
            handleApiResponse(resp.data)
    catch(Exception e)
        log.warn "SwitchBot refresh failed: ${e.message}"
def parse(String description)
    parseSwitchBotEvent(description)
def parse(Map eventMap)
    parseSwitchBotEvent(eventMap)
def parseSwitchBotEvent(eventPayload)
    if(!eventPayload)
        return false
    try
        def parsed = eventPayload
        if(eventPayload instanceof String)
            parsed = new groovy.json.JsonSlurper().parseText(eventPayload)
        if(parsed instanceof Map && parsed.context instanceof Map)
            def body = [:] + parsed.context
            if(parsed.eventType) { body.eventType = parsed.eventType }
            if(body.deviceMac && !body.deviceId) { body.deviceId = body.deviceMac }
            return handleStatusMap(body)
        if(parsed instanceof Map && parsed.body instanceof Map)
            return handleStatusMap(parsed.body)
        if(parsed instanceof Map)
            return handleStatusMap(parsed)
        logDebug("Unsupported event payload: ${parsed}")
        return false
    catch(Exception e)
        log.warn "SwitchBot event parse failed: ${e.message}"
        sendEvent(name: "apiStatus", value: "parseError")
        return false
def handleApiResponse(apiResponse)
    if(!apiResponse)
        return
    def statusCode = valueForKeys(apiResponse, ["statusCode"])
    if(statusCode != null && statusCode.toString() != "100")
        log.warn "SwitchBot API returned statusCode=${statusCode}, response=${apiResponse}"
        sendEvent(name: "apiStatus", value: "apiStatus${statusCode}")
        return
    def body = valueForKeys(apiResponse, ["body"])
    if(body instanceof Map)
        return
    if(apiResponse instanceof Map)
        handleStatusMap(apiResponse)
        return
    sendEvent(name: "apiStatus", value: "badResponse")
def handleStatusMap(Map body)
    if(!body)
        return false
    if(!payloadMatchesConfiguredDevice(body))
        logDebug("Ignoring payload for another SwitchBot device: ${body}")
        return false
    logDebug("Applying SwitchBot payload: ${body}")
    sendEvent(name: "lastUpdated", value: nowString())
    def detected = extractDetected(body)
    if(detected != null)
        def detectionState = detected ? "DETECTED" : "NOT_DETECTED"
        sendEvent(name: "detectionState", value: detectionState)
        sendEvent(name: "motion", value: detected ? "active" : "inactive")
        sendEvent(name: "presence", value: detected ? "present" : "not present")
    def battery = valueForKeys(body, ["battery", "Battery"])
    if(battery != null && isNumeric(battery))
        def batteryApiValue = clampInteger(battery, 0, 100)
        def batteryInfo = normalizePresenceBattery(batteryApiValue)
        sendEvent(name: "batteryApiValue", value: batteryApiValue, unit: "%")
        sendEvent(name: "batteryRange", value: batteryInfo.range)
        sendEvent(name: "battery", value: batteryInfo.capabilityValue, unit: "%")
    def lightLevel = valueForKeys(body, ["lightLevel", "light_level"])
    if(lightLevel != null && isNumeric(lightLevel))
        sendEvent(name: "lightLevel", value: lightLevel as Integer)
    def deviceType = valueForKeys(body, ["deviceType", "type"])
    if(deviceType != null)
        sendEvent(name: "switchbotDeviceType", value: deviceType.toString())
    def hubId = valueForKeys(body, ["hubDeviceId"])
    if(hubId != null)
        sendEvent(name: "hubDeviceId", value: hubId.toString())
    def versionValue = valueForKeys(body, ["version"])
    if(versionValue != null)
        sendEvent(name: "version", value: versionValue.toString())
    return true
def extractDetected(Map body)
    def value = valueForKeys(body, [
        "Detected",
        "detected",
        "moveDetected",
        "detectionState",
        "status",
        "humanDetected",
        "presenceDetected"
    if(value == null)
        return null
    return valueToDetected(value)
def valueToDetected(value)
    if(value instanceof Boolean)
        return value
    def normalized = value.toString().trim().toLowerCase()
    if(["true", "1", "detected", "active", "present", "occupied", "motion"].contains(normalized))
        return true
    if(["false", "0", "not_detected", "not detected", "inactive", "not_present", "not present", "unoccupied", "clear", "none"].contains(normalized))
        return false
    return null
def payloadMatchesConfiguredDevice(Map body)
    def configuredId = cleanSetting("switchbotDeviceId")
    if(!configuredId)
        return true
    def payloadId = valueForKeys(body, ["deviceId", "deviceMac", "mac"])
    if(!payloadId)
        return true
    def configured = configuredId.toString()
    def payload = payloadId.toString()
    if(configured.equalsIgnoreCase(payload))
        return true
    return normalizeId(configured) == normalizeId(payload)
def normalizeId(value)
    return value?.toString()?.replaceAll(/[^A-Fa-f0-9]/, "")?.toUpperCase()
def genParamsMain(String suffix)
    def token = cleanSetting("openToken")
    def secret = cleanSetting("secretKey")
    def apiVersion = secret ? "v1.1" : "v1.0"
    def params =
            uri: "https://api.switch-bot.com/${apiVersion}/${suffix}",
            headers:
                "Authorization": token,
                "Content-Type": "application/json; charset=utf8"
            timeout: 20
    if(secret)
        params.headers += calcSignv11(token, secret)
    return params
def calcSignv11(String token, String secret)
    def t = new Date().getTime().toString()
    def nonce = java.util.UUID.randomUUID().toString()
    def data = token + t + nonce
    return [
        t: t,
        nonce: nonce,
        sign: hmacSha256(secret, data)?.toUpperCase()
def hmacSha256(String secret, String data)
    def mac = javax.crypto.Mac.getInstance("HmacSHA256")
    def secretKeySpec = new javax.crypto.spec.SecretKeySpec(secret.getBytes("UTF-8"), "HmacSHA256")
    mac.init(secretKeySpec)
    return org.apache.commons.codec.binary.Base64.encodeBase64String(mac.doFinal(data.getBytes("UTF-8")))
def hasRequiredSettings()
    return cleanSetting("openToken") && cleanSetting("switchbotDeviceId")
def scheduleNextPoll()
    unschedule("poll")
    def seconds = pollSeconds()
    if(seconds > 0)
        runIn(seconds, "poll")
def pollSeconds()
    try
        return (pollIntervalSeconds ?: "60") as Integer
    catch(Exception ignored)
        return 60
def valueForKeys(source, List keys)
    if(!(source instanceof Map))
        return null
    for(key in keys)
        if(source.containsKey(key) && source[key] != null)
            return source[key]
        def matchingKey = source.keySet().find { it?.toString()?.equalsIgnoreCase(key.toString()) }
        if(matchingKey != null && source[matchingKey] != null)
            return source[matchingKey]
    return null
def isNumeric(value)
    try
        value as BigDecimal
        return true
        return false
def clampInteger(value, Integer min, Integer max)
    def intValue = (value as BigDecimal).intValue()
    return Math.max(min, Math.min(max, intValue))
def normalizePresenceBattery(Integer apiBattery)
    if(apiBattery >= 100)
        return [capabilityValue: 60, range: ">=60%"]
    if(apiBattery >= 60)
        return [capabilityValue: 20, range: "20-60%"]
    if(apiBattery >= 20)
        return [capabilityValue: 10, range: "10-20%"]
    if(apiBattery >= 10)
        return [capabilityValue: 0, range: "<10%"]
    return [capabilityValue: apiBattery, range: "${apiBattery}%"]
def cleanSetting(String name)
    return settings?."${name}"?.toString()?.trim()
def nowString()
    def tz = location?.timeZone ?: java.util.TimeZone.getTimeZone("UTC")
    return new Date().format("yyyy-MM-dd HH:mm:ss", tz)
def logDebug(message)
    if(debugLogging)
        log.debug "${message}"
ReadME
# SwitchBot P1 Presence Sensor for Hubitat
This repo contains a standalone Hubitat Groovy driver for the SwitchBot P1 / Presence Sensor.
The driver exposes:
- `motion`: `active` / `inactive`
- `presence`: `present` / `not present`
- `battery`: percent
- `batteryApiValue`: raw SwitchBot Cloud battery bucket
- `batteryRange`: interpreted battery range
- `lightLevel`: SwitchBot's relative light level value
- `detectionState`: raw-ish `DETECTED` / `NOT_DETECTED`
Those attributes are intended to be easy to use from webCoRE.
## Files
- `switchbotP1PresenceSensor.groovy`: install this as a Hubitat driver.
## Basic polling setup
1. In Hubitat, go to **Drivers Code** and add `switchbotP1PresenceSensor.groovy`.
2. Create a new virtual device and set its type to **SwitchBot P1 Presence Sensor**.
3. Add your SwitchBot Open Token and Secret Key.
4. Leave **SwitchBot Presence Sensor Device ID** blank, or paste the device ID if you already know it.
5. Set a polling interval. For one sensor, 60 seconds is usually reasonable; use a slower interval if you have several SwitchBot devices sharing the same API limit.
6. Click **Save Preferences**.
7. Click **autoConfigurePresenceSensor**. If exactly one `Presence Sensor` is visible from the SwitchBot API, the driver will save its device ID automatically.
8. If auto-detect finds multiple presence sensors, set **Presence Sensor Name Filter** to part of the SwitchBot device name and run **autoConfigurePresenceSensor** again.
SwitchBot exposes the Open Token and Secret Key from the SwitchBot mobile app's developer settings. The Device ID is visible from the SwitchBot OpenAPI `/devices` response; for many sensors it is the device MAC without separators.
## Battery reporting
SwitchBot Cloud does not report an exact Presence Sensor battery percentage. The OpenAPI status response reports a four-step bucket:
- API `100` means `>=60%`
- API `60` means `20-60%`
- API `20` means `10-20%`
- API `10` means `<10%`
The driver exposes the raw bucket as `batteryApiValue`, exposes the interpreted range as `batteryRange`, and sets Hubitat's standard `battery` capability to the conservative lower bound of that range. For example, if the SwitchBot app says `80%`, the API can still return `100`; the driver will now show `batteryRange: >=60%` and `battery: 60`.
## Field mapping
The driver accepts the field names currently shown in the SwitchBot OpenAPI docs and the names used by existing integrations:
- `Detected: true/false`
- `detected: true/false`
- `moveDetected: true/false`
- `detectionState: DETECTED/NOT_DETECTED`
- `battery`
- `lightLevel`
## Source references
- SwitchBot OpenAPI: https://github.com/OpenWonderLabs/SwitchBotAPI
- Existing Hubitat SwitchBot integration used as a design reference: https://github.com/tomwpublic/hubitat_switchbot
- Home Assistant SwitchBot Cloud integration behavior reference: https://www.home-assistant.io/integrations/switchbot_cloud/
