Switch turns on when another switch is dim?
I am wondering if it is possible to have 2 switches turned on, but only when a dimmer switch is dimmed below a set value. We have 2 lamps in our bedroom that are on zigbee plug in modules. I would like for those to turn on when our main bedroom lights which are z wave, are dimmed down past a certain state. I am sure there is a way to do this, but I cannot seem to figure it out in the platform. Any help would be much appreciated.
Something like this?
Yes! That solved it perfectly. I hadn't messed with the rule machine too much just yet as I am a new Hubitat user. Thank you SO much!
I would add the condition that the switch is on. Dimmer level is independent of the status of the switch. So, it's possible to have a dimmer level less than 50 and the switch being off. Which I assume, you would not want the other lights on for.
