Switch Tile On/Off Status
The tiles on my dashboard do not accurately reflect the switch status, either On or Off, primarily if I turn the switch on manually at the actual device.
Anyone have any suggestions?
what kinds of switches? can you provide a model?
does it reflect the status in the Devices menu?
They are Leviton switches, DZS15. The status does not show in the Devices menu.
It seems that the switch is Z-Wave (non plus). If this is the case, the switch may need to be polled. This can be done with the built-in app “Z-Wave Poller”.
If you give it a try, let me know if it works!
That did not work. Any other suggestions?
if I click the poll tile on the actual switch tile, it does seem to work.
It is finally working but I had to reboot the hub to get it to do so.
On another note, do you have any suggestions for a device that gets stuck on “Initializing”?
Good to hear a reboot fixed it!
Do you have a screenshot?
My first response would be to try rebooting the device by pulling the air gap if it has one, or battery if is battery operated.
Thank you.
