Hello,
I have a MHCOZY 2 Channel 5V 12V ZigBee Dry Contact Relay Switch, Adjustable Self-Lock and Momentary Interlock Working.
What switch do i selection so i can controll the Momentary time?
Hello,
The timing interval of the momentary switch cannot be changed because it is determined by hardware and is not configurable.
What about a Inching Relay what would i select then?
I am not sure I understand you. The driver for this device is "Generic zigbee multi-endpoint device". When you click Configure, it will create two child devices. Both of which are on/off switches.
If you have configured the MHCOZY hardware to be in momentary/inching mode, then when you turn the Hubitat child switch on, the following things will happen:
Whan i used the switch via ewilink i have a option to define how long the button is pressed for. Example 4secs.
That option is not exposed for the zigbee version of this switch to any zigbee coordinator that I have used.
It is exposed in the WiFi version of this switch.
