New here so be gentle.
There may be simpler apps to accomplish but trying to learn Rule Machine 4.0 after the ST days.
I have a bunch of Webcore rules where their sole purpose is to turn lights off if no motion regardless of how they were turned on. Ie physically or or by any Webcore, ST rule etc.
They restart shutdown timers if motion sensed.
Have created the below but it shuts of the switch regardless if motion sensed.
What do I need to do to correct?
Thanx, Abe
The reason that I started out down the path of using if switch is on is I have a few switches in gang boxes and believe it or not the family sometimes hits the wrong switch and just leaves it. Hard to belive, I know. This way say if they accidently turn on say the garage lights if no one is in there the lights shut off as there is no motion there. Also if you have multiple rules turning on a switch with various scenarios I only need one rule to shut off. So unfortunately using a motion sensor as the trigger does not work in some cases.
The below is what one of the basic rules look like in Webcore and works great. I have others with time of day, day of week etc restrictions.
If
Switch is on
and
All of Motion sensor 1 and Motion sensor 2 are inactive
Ah! I totally get it. Seen that a few times myself...
The problem with the rule as written in the screen shot is that once the 30 second timer is started, there is nothing in place to stop it. So when you go to the room and activate the motion detector, it still counting down and will shut down no matter what... (And slightly annoy your family member... )
What I would do then is just add your āVirtual Switch(off) turns onā trigger to the example I provided. In that case, if someone turns it on but there is no one in there, it will see that motion is inactive and turn it off after 30 seconds. If someone steps in the room before the 30 seconds, it will cancel the delayed action and keep the light on until there is no longer any motion.
Hi.
Well tried a few different things and still no luck.
Cant post pictures so it makes trying for you to help a little difficult. Will do some more searching to see if I can find something.
RM 4.0 does not seem as intuitive to me as the version that was in ST. Dont recall having this many issues on a simple rule back then.
Thanx, Abe
You may need to go through the introductory tutorial to be able to do this.
It does take some getting use to. Once you get the hang of it, it becomes relatively easy to use. It took me several months to get to that point though...
Just in case you were not yet aware, you can still use webCoRE with Hubitat (locally!). If your goal is to try out Rule Machine, then I totally get that, too.
If the switch is turned on for any reason it should only stay on if there is motion. If the motion stops then start the timer to shut off. If motion resumes reset the timer and keep light on.
Hopefully my rambling makes sense.
Thanx, Abe
that wont work becuase you also as mentioned need motion as a trigger. otherwise once the rule exits after the switch is turned on if there is motion it will never turn off.
Hi
The way I have many of my rules set up in ST is that they only turn on a light but not off. I have multiple rules and or conditions in smart lighting and webcore to accomplish this. The switch might also be turned on physically at times.
Then I have a number of webcore rules to only turn the off the light if there is motion around as well as other restrictions. Works great. Below is a simple version.
I cant use motion sensors as triggers to accomplish this as they may not change depending on the situation.
Thanx, Abe
