Suspend motion sensor after triggered
Hi, I would like to setup a motion sensor which will only be active from 6:00AM till 10:00AM that will turn on some lights and open Blinds then once triggered to suspend it for 4 hours, so basicly it only works once. I had this setup and working great in a Alexa routine which has a "suspend option" but I can not figure out how to do it in Hubitat Rule Machine..
Heres what I have now and it works but if I manually turn off one of the lights which was activated by the motion sensor and then walk past it the light comes back on.. I only want it to work once.
You could try the following.
Set up a local Private Boolean for this rule.
TRIGGER EVENTS
Motion sensor - active
10:01am
ACTIONS
IF
Time between 6 and 10am AND Private Boolean False
THEN
ON (all your current actions)
Set Private boolean true
END-IF
IF
Time between 10:00 and 10:05
THEN
Set Private Boolean false
END-IF
This should solve your issue.
I don'y use RM so there may be an easier way but from memory this should work.
