here is the original code I ported from ST for the UBS which might help for the inputs
* Device Type Definition File
* Device Type: Fibaro UBS - Dual Contact and Temperature Sensor
* File Name: Fibaro UBS - Dual Contact and Temperature Sensor.groovy
* Initial Release: 2017-11-07
* Author: Chris Charles modified by Borristhecat for hubitat and bit more mods by Dean Turner
* 5/4/2019 rebuilt all logging from Hubitat repo, altered temperature creation and fixed typo bugs by Borristhecat
* 7/4/2019 dzerovibe fixed V3 Zwave command parameters Thanks
* 7/4/2019 cleared up some logging and added default state to install method. Borristhecat
* 28/11/2019 added new parse for next firmware . Borristhecat
* 24/01/2020 happygreen frog: Bodged to use scene reporting as workaround for Silicon Labs decision to deprecate broken Fibaro firmware (who certifies this shite!!!)
* Copyright 2017 Chris Charles, based on original code by carlos.ir33, modified
* by Stuart Buchanan and Paul Crookes. Testing thanks to borristhecat.
metadata {
definition (name: "Fibaro UBS", namespace: "cjcharles0", author: "Chris Charles", importUrl: "https://raw.githubusercontent.com/borristhecat/HUBITAT/master/Fibaro%20UBS.groovy") {
capability "Contact Sensor"
capability "Motion Sensor"
capability "Sensor"
capability "Temperature Measurement"
capability "Configuration"
//capability "Polling"
capability "Refresh"
command "removeChildDevices"
command "createChildDevices"
command "createChildTempDevices"
//command "updateCurrentParams"
command "listCurrentParams"
command "open1"
command "open2"
command "close1"
command "close2"
attribute "contact1","enum",["open1","close1"]
attribute "contact2","enum",["open2","close2"]
attribute "TP1","decimal"
attribute "TP2","decimal"
attribute "TP3","decimal"
attribute "TP4","decimal"
fingerprint deviceId: "1002", inClusters: "0x30,0x60,0x85,0x8E,0x72,0x70,0x86,0x7A", outClusters: "0x2B", mfr: "010F", deviceJoinName: "Fibaro UBS"
//fingerprint type: "1281", cc: "30 60 85 8E 72 70 86 7A", ccOut: "2B"
//main(["temperature1"]) //, "contact1"
// details(["contact1","contact2",
// "temp1text", "TP1", "temp2text", "TP2",
// "temp3text", "TP3", "temp4text", "TP4",
// "configure", "report", "createchildren", "createtempchildren", "removechildren"])
preferences {
//standard logging options
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
input name: "settingEnable", type: "bool", title: "Enable setting", defaultValue: false
input name: "IP1Type", type: "enum", title: "Input 1 Type",
options: ["Contact", "Motion"], defaultValue: "Contact", displayDuringSetup: false
input name: "IP2Type", type: "enum", title: "Input 2 Type",
input name: "Temps", type: "number", range: "0..4", required: true, defaultValue: "0",
title: "Temperature probes number. \n" +
"Default value: 0."
// input name: "Info", type: "paragraph", title:"Device Handler by @cjcharles", description: "Parameter Settings:", displayDuringSetup: false
if (settingEnable) input name: "param1", type: "number", range: "0..65535", required: true, defaultValue: "0",
title: "Parameter No. 1 - Input 1 Alarm Cancellation Delay. \n" +
"Additional delay after an alarm from input 1 has ceased.\n" +
"Time in seconds to delay the ceasing event.\n" +
"Default value: 0."
if (settingEnable) input name: "param2", type: "number", range: "0..65535", required: true, defaultValue: "0",
title: "Parameter No. 2 - Input 2 Alarm Cancellation Delay. \n" +
"Additional delay after an alarm from input 2 has ceased.\n" +
"Default value: 0."
if (settingEnable) input name: "param3", type: "number", range: "0..3", required: true, defaultValue: "1",
title: "Parameter No. 3 - Type of Input No 1." +
"Available settings:\n" +
"0 – INPUT_NO (Normal Open)\n" +
"1 – INPUT_NC (Normal Close)\n" +
"2 – INPUT_MONOSTABLE\n" +
"3 – INPUT_BISTABLE\n" +
"Default value: 1."
if (settingEnable) input name: "param4", type: "number", range: "0..3", required: true, defaultValue: "1",
title: "Parameter No. 4 - Type of Input No 2." +
"Default value: 1."
if (settingEnable) input name: "param5", type: "number", range: "0..255", required: true, defaultValue: "255",
title: "Parameter No. 5 - Type of transmitted control or alarm frame for association group 1." +
"0 – Frame ALARM GENERIC\n" +
"1 – Frame ALARM SMOKE\n" +
"2 – Frame ALARM CO\n" +
"3 – Frame ALARM CO2\n" +
"4 – Frame ALARM HEAT\n" +
"5 – Frame ALARM WATER\n" +
"255 – Control frame BASIC_SET\n" +
"Default value: 255."
if (settingEnable) input name: "param6", type: "number", range: "0..255", required: true, defaultValue: "255",
title: "Parameter No. 6 - Type of transmitted control or alarm frame for association group 2." +
if (settingEnable) input name: "param7", type: "number", range: "0..255", required: true, defaultValue: "255",
title: "Parameter No. 7 - Value of the parameter specifying the forced level of dimming / opening sun blinds when " +
"sent a “switch on” / ”open” command from association group no. 1.\n" +
"0-99 - Dimming or Opening Percentage\n" +
"255 - Last set percentage\n" +
if (settingEnable) input name: "param8", type: "number", range: "0..255", required: true, defaultValue: "255",
title: "Parameter No. 8 - Value of the parameter specifying the forced level of dimming / opening sun blinds when " +
"sent a “switch on” / ”open” command from association group no. 2.\n" +
if (settingEnable) input name: "param9", type: "number", range: "0..3", required: true, defaultValue: "0",
title: "Parameter No. 9 - Deactivating transmission of the frame cancelling the alarm or the " +
"control frame deactivating the device (Basic). Disable the alarm cancellation function.\n" +
"0 – Cancellation sent for association group 1 and 2\n" +
"1 – Cancellation sent for association group 1 only\n" +
"2 – Cancellation sent for association group 2 only\n" +
"3 - Not sent for association group 1 or 2\n" +
"Default value: 0."
if (settingEnable) input name: "param10", type: "number", range: "1..255", required: true, defaultValue: "20",
title: "Parameter No. 10 - Interval between successive readings of temperature from all " +
"sensors connected to the device. (A reading does not result in sending to HE)\n" +
"1-255 - Seconds between readings\n" +
"Default value: 20."
if (settingEnable) input name: "param11", type: "number", range: "0..255", required: true, defaultValue: "200",
title: "Parameter No. 11 - Interval between forcing to send report of the temperature. " +
"The forced report is sent immediately after the next temperature reading, " +
"irrespective of parameter 12. Advised to be 200 unless rapid temperature changes are expected.\n" +
"0 - Deactivate temperature sending\n" +
"1-255 - Seconds between sends\n" +
"Default value: 200."
if (settingEnable) input name: "param12", type: "number", range: "0..255", required: true, defaultValue: "8",
title: "Parameter No. 12 - Insensitiveness to temperature changes. This is the maximum " +
"difference between the last reported temperature and the current temperature. " +
"If they differ by more than this then a report is sent.\n" +
"0-255 - x/16 = temp diff in C\n" +
"x/80*9 = temp diff in F\n" +
"Default value: 8 (0.5oC)."
if (settingEnable) input name: "param13", type: "number", range: "0..3", required: true, defaultValue: "0",
title: "Parameter No. 13 - Transmitting the alarm or control frame in “broadcast” mode (i.e. to " +
"all devices within range), this information is not repeated by the mesh network." +
"0 - IN1 and IN2 broadcast inactive,\n" +
"1 - IN1 broadcast mode active only,\n" +
"2 - IN2 broadcast mode active only,\n" +
"3 - INI and IN2 broadcast mode active.\n" +
"Default value: 0."
//if (settingEnable) input name: "param14", type: "number", range: "0..1", required: true, defaultValue: "1",
// title: "Parameter No. 14 - Scene activation functionality." +
// "Available settings:\n" +
// "0 - Deactivated functionality,\n" +
// "1 - Activated functionality.\n" +
// "Default value: 0."
def installed() {
if (txtEnable) log.info "installed()"
state.ContactUsed = true
state.MotionUsed = false
def uninstalled() {
if (txtEnable) log.info "uninstalled()"
removeChildDevices()
def configure() {
log.warn "configure()"
updateCurrentParams()
def logsOff(){
log.warn "debug logging disabled..."
device.updateSetting("logEnable",[value:"false",type:"bool"])
def SettingsOff(){
log.warn "Settings disabled..."
device.updateSetting("settingEnable",[value:"false",type:"bool"])
def refresh() {
log.info "refresh"
def cmds = []
switch(Temps){
case 0:
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:32, command:2).format()
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2, commandClass:32, command:2).format()
return delayBetween(cmds, 1500)
break;
case 1:
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:3, destinationEndPoint:3, commandClass:49, command:5).format()
break;
case 2:
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:4, destinationEndPoint:4, commandClass:49, command:5).format()
break;
case 3:
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:5, destinationEndPoint:5, commandClass:49, command:5).format()
break;
case 4:
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:6, destinationEndPoint:6, commandClass:49, command:5).format()
break;
def createChildDevices(){
log.info "Adding Child Devices if not already added"
//for (i in 1..2) {
for (i in 1) {
try {
if (txtEnable) log.info "Trying to create child switch if it doesn't already exist ${i}"
def currentchild = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-IP${i}"}
if (currentchild == null) {
if (txtEnable) log.info "Creating child for IP${i}"
if (IP1Type == "Contact") addChildDevice("hubitat", "Virtual Contact Sensor", "${device.deviceNetworkId}-IP${i}", [name: "${device.displayName} (Contact${i})", isComponent: true])
if (IP1Type == "Motion") addChildDevice("hubitat", "Virtual Motion Sensor", "${device.deviceNetworkId}-IP${i}", [name: "${device.displayName} (Contact${i})", isComponent: true])
} catch (e) {
if (txtEnable) log.debug "Error adding child ${i}: ${e}"
for (i in 2) {
try {
if (IP2Type == "Contact") addChildDevice("hubitat", "Virtual Contact Sensor", "${device.deviceNetworkId}-IP${i}", [name: "${device.displayName} (Contact${i})", isComponent: true])
if (IP2Type == "Motion") addChildDevice("hubitat", "Virtual Motion Sensor", "${device.deviceNetworkId}-IP${i}", [name: "${device.displayName} (Contact${i})", isComponent: true])
} catch (e) {
def createChildTempDevices() {
switch(Temps){
case 1:
for (i in 1) {
if (txtEnable) log.info "Creating 1 Temperature child"
def currentchild = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-TP${i}"}
addChildDevice("hubitat", "Virtual Temperature Sensor", "${device.deviceNetworkId}-TP${i}", [name: "${device.displayName} (Temp${i})", isComponent: true])
break
case 2:
for (i in 1..2) {
if (txtEnable) log.info "Creating 2 Temperature child's"
break
case 3:
for (i in 1..3) {
if (txtEnable) log.info "Creating 3 Temperature child's"
break
case 4:
for (i in 1..4) {
if (txtEnable) log.info "Creating 4 Temperature child's"
break
case 0:
if (txtEnable) log.info "Not creating any Temperature children as value is set to 0"
break
private removeChildDevices() {
log.info "Removing Child Devices, if any installed"
try {
getChildDevices()?.each {
try {
deleteChildDevice(it.deviceNetworkId)
} catch (e) {
log.debug "Error deleting ${it.deviceNetworkId}, probably locked in a App: ${e}"
} catch (err) {
log.debug "Either no children exist or error finding child devices for some reason: ${err}"
/*def parse(String description) {
def result = null
def cmd = zwave.parse(description, [ 0x60: 3])
if (cmd) {
result = zwaveEvent(cmd)
if (logEnable) log.debug "parsed '$description' to result: ${result}"
return result
if (logEnable) log.trace "description:${description}"
if (logEnable) log.debug "parse description: ${description}"
def cmd = zwave.parse(description,[ 0x20:1, 0x26: 1])
if (cmd) {zwaveEvent(cmd)}
return
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv1.ManufacturerSpecificReport cmd) {
if (txtEnable) log.info("ManufacturerSpecificReport ${cmd.inspect()}")
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
if (txtEnable) log.info("ConfigurationReport ${cmd.inspect()}")
def createEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd, Map item1) {
if (txtEnable) log.info "manufacturerId: ${cmd.manufacturerId}"
if (txtEnable) log.info "manufacturerName: ${cmd.manufacturerName}"
if (txtEnable) log.info "productId: ${cmd.productId}"
if (txtEnable) log.info "productTypeId: ${cmd.productTypeId}"
def createEvent(hubitat.zwave.commands.versionv1.VersionReport cmd, Map item1) {
updateDataValue("applicationVersion", "${cmd.applicationVersion}")
if (txtEnable) log.info "applicationVersion: ${cmd.applicationVersion}"
if (txtEnable) log.info "applicationSubVersion: ${cmd.applicationSubVersion}"
if (txtEnable) log.info "zWaveLibraryType: ${cmd.zWaveLibraryType}"
if (txtEnable) log.info "zWaveProtocolVersion: ${cmd.zWaveProtocolVersion}"
if (txtEnable) log.info "zWaveProtocolSubVersion: ${cmd.zWaveProtocolSubVersion}"
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
if (logEnable) log.debug "BasicSet V1 ${cmd.inspect()}"
if (state.ContactUsed) def currentstate
if (state.MotionUsed) def motionstate
if (cmd.value) {
if (state.ContactUsed) currentstate = "open"
if (state.MotionUsed) motionstate = "inactive"
} else {
if (state.ContactUsed) currentstate = "closed"
if (state.MotionUsed) motionstate = "active"
if (state.ContactUsed) createEvent(name: "contact${cmd.sourceEndPoint}", value: currentstate, descriptionText: "${device.displayName} is ${currentstate}", type: "physical")
if (state.MotionUsed) createEvent(name: "contact${cmd.sourceEndPoint}", value: motionstate, descriptionText: "${device.displayName} is ${motionstate}", type: "physical")
try {
def childDevice = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-IP${cmd.sourceEndPoint}"}
if (childDevice)
if (state.MotionUsed) childDevice.sendEvent(name: "motion", value: motionstate, descriptionText: "IP${cmd.sourceEndPoint} is ${motionstate}", type: "physical")
if (state.ContactUsed) childDevice.sendEvent(name: "contact", value: currentstate, descriptionText: "IP${cmd.sourceEndPoint} is ${currentstate}", type: "physical")
if (txtEnable) log.info "Fibaro is ${motionstate} and ${currentstate}"
} catch (e) {
log.error "Couldn't find child device, probably hasn't been created yet? Please click create child devices. Error: ${e}"
def zwaveEvent(hubitat.zwave.commands.multichannelv4.MultiChannelCmdEncap cmd) {
if (logEnable) log.debug "ZWaveEvent V4 ${cmd.inspect()}"
def result
if (cmd.commandClass == 32) {
if (cmd.parameter[0] == 0) {
if (cmd.parameter[0] == 255) {
if (txtEnable) log.info "IP${cmd.sourceEndPoint} is ${currentstate}"
//First update tile on this device
if (state.ContactUsed) sendEvent(name: "contact${cmd.sourceEndPoint}", value: currentstate, descriptionText: "$device.displayName - IP${cmd.sourceEndPoint} is ${currentstate}", type: "physical")
if (state.MotionUsed) sendEvent(name: "contact${cmd.sourceEndPoint}", value: motionstate, descriptionText: "$device.displayName - IP${cmd.sourceEndPoint} is ${motionstate}", type: "physical")
//If not null then we have found either IP1 or IP2, hence try to send to the child device aswell
try {
if (childDevice)
} catch (e) {
else if (cmd.commandClass == 49) {
if ((cmd.sourceEndPoint >= 3) && (cmd.sourceEndPoint <= 6)) {
def tempsensorid = cmd.sourceEndPoint - 2
def tempendpoint = "TP" + tempsensorid.toString()
def tempval = ((cmd.parameter[4] * 256) + cmd.parameter[5])
if (tempval > 32767) {
//Here we deal with negative values
tempval = tempval - 65536
//Finally round the temperature
def tempprocessed = (tempval / 100).toDouble().round(1)
def units = getTemperatureScale()
//def cmdScale = cmd.scale == 1 ? "F" : "C"
//def tempval = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision).toDouble().round(1)
if (txtEnable) log.info "${tempendpoint} has changed to ${tempprocessed}${units}"
sendEvent(name: tempendpoint, value: tempprocessed, descriptionText: "$device.displayName - ${tempendpoint} is ${tempprocessed}", displayed: true, unit: units, type: "physical")
//If not null then we have found either contact1 or contact2, hence try to send to the child
try {
def childDevice = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-${tempendpoint}"}
if (childDevice)
//We found a child device that matches so send it the new temperature
childDevice.sendEvent(name: "temperature", value: tempprocessed, descriptionText: "$device.displayName - ${tempendpoint} is ${tempprocessed}", unit: units, type: "physical")
} catch (e) {
//Not an error message here as people may not want child temperature devices
log.debug "Couldn't find child ${tempendpoint} device, probably hasn't been created yet? Please click create child Temp devices. Error: ${e}"
else {
//Send them here just in case we want to do more complicated processing (not doing it as need to have endpoint passed and that makes it a bit messy)
def encapsulatedCommand = cmd.encapsulatedCommand([0x31: 2, 0x60: 3, 0x85: 2, 0x8E: 2, 0x72: 1, 0x70: 1, 0x86: 1, 0x7A: 1, 0xEF: 1, 0x2B: 1]) // can specify command class versions here like in zwave.parse
if (logEnable) log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")
if (encapsulatedCommand) {
result = zwaveEvent(encapsulatedCommand)
return result
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd)
//This is no longer used as caught in an earlier event, but kept here in case the code is useful
if (logEnable) log.debug "Sensor MultiLevel Report - Sensor Type = ${cmd.sensorType}"
switch (cmd.sensorType) {
case 1:
// temperature
sendEvent(name: "TP${cmd.sourceEndPoint}", value: tempprocessed, displayed: true, unit: units, type: "physical")
break;
if (logEnable) log.debug map
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd) {
if (logEnable) log.debug "SensorMultilevelReport $cmd"
//Added by JG
def zwaveEvent(hubitat.zwave.commands.sceneactivationv1.SceneActivationSet cmd) {
log.debug(cmd)
log.debug "sceneId: ${cmd.sceneId}"
//log.debug "dimmingDuration: ${cmd.dimmingDuration}"
def contactname = "contact2"
def childid = "2"
switch (cmd.sceneId) {
case 10: // IP1 de-asserted
contactname = "contact1"
childid = "1"
case 20: // IP2 de-asserted
break
case 11: // IP1 asserted
childid = "1"
case 21: // IP2 asserted
break
default:
logging("Unhandled SceneActivationSet: ${cmd}")
return
break
if (txtEnable) log.info "IP${childid} is ${currentstate}"
if (state.ContactUsed) sendEvent(name: contactname, value: currentstate, descriptionText: "$device.displayName - contactname is ${currentstate}", type: "physical")
if (state.MotionUsed) sendEvent(name: contactname, value: motionstate, descriptionText: "$device.displayName - contactname is ${motionstate}", type: "physical")
try {
def childDevice = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-IP${childid}"}
if (childDevice)
if (state.MotionUsed) childDevice.sendEvent(name: "motion", value: motionstate, descriptionText: "IP${childid} is ${motionstate}", type: "physical")
if (state.ContactUsed) childDevice.sendEvent(name: "contact", value: currentstate, descriptionText: "IP${childid} is ${currentstate}", type: "physical")
} catch (e) {
def zwaveEvent(hubitat.zwave.Command cmd) {
// This will capture any commands not handled by other instances of zwaveEvent
// and is recommended for development so you can see every command the device sends
if (txtEnable) log.info "Catchall reached for cmd: ${cmd.toString()}}"
if (txtEnable) return createEvent(descriptionText: "${device.displayName}: ${cmd}")
def updateCurrentParams() {
log.warn "Sending configuration parameters to ${device.displayName}"
log.debug "Param 14 setting = ${param14.value}"
def cmds = []
cmds << zwave.multiChannelAssociationV2.multiChannelAssociationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format()
cmds << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
cmds << zwave.associationV1.associationRemove(groupingIdentifier:1, nodeId:zwaveHubNodeId).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param1 == null ? 0 : param1.value, parameterNumber: 1, size: 2).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param2 == null ? 0 : param2.value, parameterNumber: 2, size: 2).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param3 == null ? 1 : param3.value, parameterNumber: 3, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param4 == null ? 1 : param4.value, parameterNumber: 4, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param5 == null ? 255 : param5.value, parameterNumber: 5, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param6 == null ? 255 : param6.value, parameterNumber: 6, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param7 == null ? 255 : param7.value, parameterNumber: 7, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param8 == null ? 255 : param8.value, parameterNumber: 8, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param9 == null ? 0 : param9.value, parameterNumber: 9, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param10 == null ? 20 : param10.value, parameterNumber: 10, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param11 == null ? 200 : param11.value, parameterNumber: 11, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param12 == null ? 8 : param12.value, parameterNumber: 12, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param13 == null ? 0 : param13.value, parameterNumber: 13, size: 1).format()
//cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: param14 == null ? 0 : param14.value, parameterNumber: 14, size: 1).format()
cmds << zwave.configurationV1.configurationSet(scaledConfigurationValue: 1, parameterNumber: 14, size: 1).format()
return delayBetween(cmds, 500)
def listCurrentParams() {
log.info "Listing of current parameter settings of ${device.displayName}"
def cmds = []
cmds << zwave.multiChannelAssociationV2.multiChannelAssociationGet(groupingIdentifier:2).format()
cmds << zwave.associationV2.associationGet(groupingIdentifier: 3).format()
cmds << zwave.associationV1.associationGet(groupingIdentifier: 1).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 1).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 2).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 3).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 4).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 5).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 6).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 7).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 8).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 9).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 10).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 11).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 12).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 13).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 14).format()
def open1() {
if (IP1Type == "Contact") sendEvent(name: "contact1", value: "open", descriptionText: "$device.displayName - IP1 was set to open", type: "digital")
if (IP1Type == "Motion") sendEvent(name: "contact1", value: "inactive", descriptionText: "$device.displayName - IP1 was set to inactive", type: "digital")
try {
def childDevice = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-IP1"}
log.info "Changing child ${childDevice} to open/inactive"
if (childDevie)
if (IP1Type == "Motion") childDevice.sendEvent(name: "motion", value: "inactive", descriptionText: "$device.displayName - IP1 was set to inactive", type: "digital")
if (IP1Type == "Contact") childDevice.sendEvent(name: "contact", value: "open", descriptionText: "$device.displayName - IP1 was set to open", type: "digital")
} catch (e) {
def close1() {
if (IP1Type == "Contact") sendEvent(name: "contact1", value: "closed", descriptionText: "$device.displayName - IP1 was set to closed", type: "digital")
if (IP1Type == "Motion") sendEvent(name: "contact1", value: "active", descriptionText: "$device.displayName - IP1 was set to active", type: "digital")
try {
log.info "Changing child ${childDevice} to closed/active"
if (childDevice)
if (IP1Type == "Motion") childDevice.sendEvent(name: "motion", value: "active", descriptionText: "$device.displayName - IP1 was set to active", type: "digital")
if (IP1Type == "Contact") childDevice.sendEvent(name: "contact", value: "closed", descriptionText: "$device.displayName - IP1 was set to closed", type: "digital")
} catch (e) {
def open2() {
if (IP2Type == "Contact") sendEvent(name: "contact2", value: "open", descriptionText: "$device.displayName - IP2 was set to open", type: "digital")
if (IP2Type == "Motion") sendEvent(name: "contact2", value: "inactive", descriptionText: "$device.displayName - IP2 was set to inactive", type: "digital")
try {
def childDevice = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-IP2"}
if (childDevice)
if (IP2Type == "Motion") childDevice.sendEvent(name: "motion", value: "inactive", descriptionText: "$device.displayName - IP2 was set to inactive", type: "digital")
if (IP2Type == "Contact") childDevice.sendEvent(name: "contact", value: "open", descriptionText: "$device.displayName - IP2 was set to open", type: "digital")
} catch (e) {
def close2() {
if (IP2Type == "Contact") sendEvent(name: "contact2", value: "closed", descriptionText: "$device.displayName - IP2 was set to closed", type: "digital")
if (IP2Type == "Motion") sendEvent(name: "contact2", value: "active", descriptionText: "$device.displayName - IP2 was set to active", type: "digital")
try {
if (childDevice)
if (IP2Type == "Motion") childDevice.sendEvent(name: "motion", value: "active", descriptionText: "$device.displayName - IP2 was set to active", type: "digital")
if (IP2Type == "Contact") childDevice.sendEvent(name: "contact", value: "closed", descriptionText: "$device.displayName - IP2 was set to closed", type: "digital")
} catch (e) {
//capture preference changes
def updated() {
log.info "updated()"
log.warn "debug logging is: ${logEnable == true}"
log.warn "description logging is: ${txtEnable == true}"
log.warn "Settings is: ${settingEnable == true}"
if (logEnable) runIn(1800,logsOff)
if (settingEnable) runIn(2100,SettingsOff)
// Check for any null settings and change them to default values
if (IP1Type == null) IP1Type = "Contact"
if (IP2Type == null) IP2Type = "Contact"
// is contact or motion used or both
if (IP1Type == "Contact" || IP2Type == "Contact") { state.ContactUsed = true
if (txtEnable) log.info "At least 1 Contact used"
} else { state.ContactUsed = false
if (txtEnable) log.info "Contact's not used"
if (IP1Type == "Motion" || IP2Type == "Motion") { state.MotionUsed = true
if (txtEnable) log.info "At least 1 Motion used"
} else { state.MotionUsed = false
if (txtEnable) log.info "Motion not used"
