So I have successfully installed Super Tile and have seemed to have configured all correctly (and even waited for polling to make sure null is replaced).
Q1: Image location
I see that we can have icons, and one of the config fields is to insert the URI (http:// or https://). One of the main reasons I moved to HE is the local control...so, where can I store any icons locally to use? Does the HE have local onboard storage? Can I reference my internal network (NAS hosting)?
Q2: Device Attributes
When configuring the columns, on lines, one of the choices is to select "Device Attribute". Where can I find a list of attributes? Does HE scrub and normalize the attributes from the many disparate officially (and unofficially) supported devices? Sometimes (in other HE apps) I need to wrap config options in percentage-signs (that didn't work for my first Super Tile) nor did just using the name (I'm trying to access the temperature, humidity and battery attributes from my TempHumidity sensor).
I have mine on a local Raspberry Pi web-server (it must be a web server not a network share)
Super Tile can use any attribute (standard or otherwise) from any device.
You can find the attributes available on the device page.
(Go to βdevicesβ on the main HE menu then select the relevant device.
You will see the attributes on the right-hand side of the page.
You need to do each attribute individually and the attribute configuration does not require any % sign or anything else
Attributes are also case sensitive.
Temperature is not the same as temperature
BTW
If you have questions about a community app it is always better to ask them in the original release thread.
Some authors restrict their replies to these threads.
Also, when the author answers, the answer is there for other, new users, to see
