Suggestions on Zwave errors
Any suggestions on where to start with this many failed devices? At one point I was pretty stable but slow. I do have a couple devices that are non-responsive which is why I did the upgrade and repair.
Hubitat Elevation® Platform Version
2.2.4.145
Did a reboot and got down to 2. These are very close to other devices though and one near the hub so not sure why. Will try playing around more tomorrow.
you dont need to be doing full repair .. just do node level repairs on those individual nodes.
And probably more important, are those nodes working?
I thought not doing a full repair was now old-school given the new release follows a topology methodology?
Yes these two devices are non-responsive. One is stuck on and one off..
Yes, you should be able to do a repair. But there are some lingering radio issues on the C7 that are still being worked on. Repair exacerbates the issues so you don't want to do it unnecessarily.
If the two devices are Plus, I would recommend physically operating each device a few times to see if it fixes itself with the hub.
Ok thanks. Will give that a try before unpairing.
