Suggestions for identifying what is turning on a Hue Lighting Group
I have some rogue lights in the Guest Bedroom that are turning on randomly.
I cannot see what is causing it in the logs, off checking Hue Hubs
Do you use Alexa? I've seen a bunch of posts that turned out to be her. She has a setting called Hunches where she tries to decide that you want the lights on and turns em on.
Assuming you're using a Hue Bridge, the source could exist inside or outside Hubitat, so checking those for any schedule/automations is a good idea. On the Hubitat side, you can look at the "In Use By" section on the device page to see any apps that reference the device, and you can then check the apps to see if they'd be doing this. Since this is a group, you'll likely want to check both the group device itself and any "member bulbs" that comprise it, since that could effectively also make the group be "on," too.
One odd thing some peope have noticed: do you have an Amazon Alexa device, and is the "hunches" feature enabled? This has been a source of odd things like this with lights for some people in the recent past.
I found it.
It was an old Motion Sensor I used to use in there.
It was in a draw in my office.
Hue was still using it and turning them on at what appeared random.
Taken batteries out and it fixed the issue now.
thank you guys -
