Many other apps specific to devices (Kasa, AiDot, etc.) have the ability to allow multiple triggers for something to happen when setting up smart routines. For example, if I want holiday lights to come on at 5:30 AM (then shut them off with another routine say at sunrise), and also want the lights to come on at sunset (then shut them off at a later time), I only have to create two routines: one to turn them on and another to turn them off. In each routine there is an "Or" event trigger.
But I have to create four separate "apps" in Hubitat to accomplish the same thing: separate ones for each turn-on and turn off times/events. Am I missing something?
Any rule can have multiple triggers, which are OR'd. From the app's first screen, "Select Trigger Events", and then "Create New Trigger Event" as many times as you want:
The OP is referring to Basic Rules app, which only permits a single Trigger. But as you've pointed out, what he seeks exists in Rule Machine, for when you get beyond "basic" rules.
