I have a device that @thebearmay made for me that allows us to display, add, and take points that we give the kids for good behavior etc. I am trying to figure out a way to use RM to automatically add points at a specific time every week.
I have the trigger all ready sorted. I just am not sure how the management of variables would work.
This what the device page looks like if that is helpful at all.
Every Sunday at 9 pm I want to add 500 points to whatever the current value is.
See if the setVariable command is under custom actions…
It is but I'm not sure how to accomplish "+500"
Is there a way to enter something here that adds to current value instead of overwriting it?
Try this version of the driver and use the custom command increment
Custom Dashboard Connector
* Dashboard Variable w/Increment
* Licensed Virtual the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
static String version() { return '0.2.0' }
metadata {
definition (
name: "Dashboard Variable Device 2",
namespace: "thebearmay",
author: "Jean P. May, Jr.",
importUrl:"https://raw.githubusercontent.com/thebearmay/hubitat/main/dashVariable.groovy"
capability "Actuator"
capability "Sensor"
attribute "variable", "string"
//This one works with the dashboard
command "setVariable", [[name:"variable", type:"STRING", description:"Both commands store the same variable. Dashboard tile type applies constraints at the dashboard."]]
//This one works in webCore without generating a warning message
command "setVariableAlt", [[name:"variable", type:"STRING", description:"Both commands store the same variable. Dashboard tile type applies constraints at the dashboard."]]
command "increment", [[name:"incValue", type:"NUMBER"]]
preferences {
input("debugEnable", "bool", title: "Enable debug logging?")
def installed() {
log.trace "installed()"
setVariable("installed")
def updated(){
log.trace "updated()"
if(debugEnable) runIn(1800,logsOff)
def setVariable(varStr) {
if(debugEnable) log.debug "setVariable() $varStr"
sendEvent(name:"variable", value:varStr)
def setVariableAlt(varStr) {
if(debugEnable) log.debug "setVarALt() $varStr"
setVariable(varStr)
def increment(incValue){
try {
incWork = device.currentValue("variable").toFloat() + incValue
sendEvent(name:"variable", value:incWork)
}catch (ignore) {
log.error "Parsing error - variable value '${device.currentValue("variable")}' is not a number"
void logsOff(){
device.updateSetting("debugEnable",[value:"false",type:"bool"])
Amazing! I was not at all expecting a custom solution! Thank you so much! I'll give it a shot on my lunch break today.
