Strange warning message log - am warnReceived local request for App
FW 2.2.3 has been an adventure to say the least, this morning I'm seeing these warning messages in the log. I'm guessing this is due to an app I deleted.
How can I clean this up?
sys:12020-08-16 10:05:21.197 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
sys:12020-08-16 09:57:28.178 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
sys:12020-08-16 08:45:44.742 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
sys:12020-08-16 08:45:33.784 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
sys:12020-08-16 08:44:47.962 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
sys:12020-08-16 08:43:30.774 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
sys:12020-08-16 08:41:03.436 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
sys:12020-08-16 08:38:26.925 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
sys:12020-08-16 07:50:07.109 am warnReceived local request for App 1250 that does not exist, path: /pwh from unknown
You have something making a webrequest to your hub for app 1250. What that app used to be, well, that's anybody's guess. What systems do you have set up at home that might be making web calls to your hub? MQTT? Node-Red? Shortcuts on an android or iOS device? It's definitely coming in on your local network and not through the cloud so that should at least start to limit things.
The only way to "clean this up" is to stop that other system from sending messages to your hub. The hub is the one receiving the messages. It can't force the other system to stop sending it messages.
Have you uninstalled a lot of apps recently? If it wasn't too long ago you can always restore a backup if you have one.
@johnwick - thank you for your reply. I have been removing lots of dead wood from HE trying to lean it out. One app I removed was one that managed messages from Plex, but hadn't updated Plex to stop sending the webhooks. It's all good now, thanks again.
