I just installed a V1 Iris smart button and set it to turn on and off a light plugged into a Iris V1 control switch with a Rule. I tried setting 1 rule to turn the light on and another to turn it off. However, no matter what settings I use whenever the light is turned on it blinks 2 times before it stays on. Pressing the button again to turn the light off is not a problem. I deleted both rules and remade them, and I also tried rebooting the hub to no avail. I tried unplugging the control switch, and I also tried amending the rule so that instead of having two rules (one to turn the light on and another to turn it off) I instead set the rule to toggle the switch on and off. None of this has worked. Every time the light gets turned on, it continues to blink 2 times before it stays on. Can anybody guess what I am doing wrong, or what I can do to resolve this issue? Currently running 2.3.4.120. Thank you all!
UPDATE: I removed the button and reinstalled it and created a new rule to toggle the control switch on and off again. Same issue persists: light turns off normally but upon turning it on it blinks twice before it stays on. I'm at a loss what I'm doing wrong...
UPDATE 2: the issue is now also affecting turning the light on and off via the dashboard (meaning without using the rule and the smart button). Before I tried installing the smart button, I could turn the light on and off via the dashboard without this blinking behavior happening.
UPDATE 3: trying to find the issue by process of elimination, I removed the control switch, deleted it form the rules that were associated with it, and then repair it and readded it to the rules. Issue still persists despite reinstalling the control switch. Baffling.
