So something strange is going. Every time I hit configure for one of my Front Entry Generic Zigbee Motion sensor (stock DH), my Garage Entry Zooz Mini Sensor (NEO Coolcam Motion Sensor DH) changes state to ACTIVE. This then cause my HSM intrusion alert to triggered but then I can't seems to cancel the alert when I hit cancel alert.
I tried it with another generic zigbee motion sensor and it does not show the same issue. The thing that's different is the Front Entry Generic Zigbee motion sensor is stuck on ACTIVE.
There's no way that sending configuration commands to a zigbee device can change the state of a zwave device...
And even if this were possible, the zwave event wouldn't be 7 ish seconds later.
Are you doing any polling on either of these sensors?
Ok, If I disable this HSM rule, and the intrusion alert comes in, I am able to clear it. BUT, if a second alert comes in, I can't no longer clear it. ONLY can clear one time after arming the rule.
Finally home to take a look at it. It turns out that motion sensor was not the one I thought it was. It's an IRIS motion sensor 3326-L that was sitting next to the zwave sensor. AND that motion sensor died while ago with the symptom of constant motion ACTIVE, I couldn't get it go inactive. I replaced it with the zwave version but didn't actually removed it from HE. Strange that the problem is just starting today.
It's now removed from HE and battery also removed. Going to monitor this for few days.
I know right.. the frequency are so far apart from each other. But once I removed it, I am no longer having the issue. But as a test, I re-added that sensor to HE again but can't get it to duplicate anymore.
anyway,, I am not going to di*k around with it anymore. All good again for now
