This evening, I had an episode of strange behavior with the CT101 Radio Thermostat. It had been operating correctly since installing in Hubitat and configuring. However, this evening I notied that the house was rather warm. It turns out that somehow, the thermostat got placed in "away mode" settings which meant that instead of 75 degrees changing to 74 degrees at 23:30, it was stuck on 80 degrees. Even after a hub reset it did not correct itself. It was not until I finally hit "Refresh" on the device page that it seemed to finally respond. The thermostat is connected to power so it should not go to sleep. We did have a power outage of several hours duration last week, but after the power was restored it had been operating properly until this evening.
Should I just chalk it up to a temporary glitch? I will be observing it more closely to make sure it is behaving as expected now. Hopefully, this is not something indicating that the thermostat is having problems that will require a replacement.
