Still Having Issues With Modes
I'm still having an Issue with My Modes and HSM Arm/Disarm. Modes have been switching at midnight I believe since recent updates but certainly could be something I screwed up. This in turn Disarms my HSM at Midnight. Like last night my speaker that says "System Disarmed" woke me at midnight. I opened my phone app and it was disarmed and mode was DAY which should have been NIGHT It does seem to act differently on different days but I do have different set ups for different days. I'm reaching out for help in finding the solution.
ModeProb1
I don't know if this is the issue or not but can you use Set Modes based on time of day AND set modes by day.
When the day changes from Thu to Fri for example, then at 00:00 on Fri it will set to day. 00:00 on Thurs will set it to dawn.
I'm not using it the way you are but that seems logical to me that this is what will happen. (Probably totally wrong. :wink: )
What happens if you just use the top option and delete everything in the second option.
As I say, not sure if my thinking is correct but that seems to make sense to me.
In retrospect, the problem may have started when I decided to not Disarm every morning at 5am. I wanted it to be later on Fri, Sat and Sun, when it switched to Day Mode. If this is indeed the issue is there a way to achieve what I want?
TBH I don't know. I only arm/disarm when mode changes to away/anything other than.
Ok, thanks for your input.
