ST Motion Sensor missing in Simple Lighting
Just received my hub and I've started moving devices from ST.
I have successfully set up two ST motion sensors - both seemed to have paired correctly.
I've also added my Hue lights (still connected via Hub bridge).
I've installed the Smart Lighting app. When I try to set the motion sensor used only one appears as a choice; the other doesn't appear at all in the drop down.
Any suggestions on how to get the other motion sensor to show? It's a ST 2014 motion sensor (as mentioned it seems to have paired correctly). The one that does show on the drop down, BTW, is a ST 2014 model (going old school) :slight_smile:
Any advice would be appreciated.
Thanks.
Does it show up as a motion sensor in rule machine? If not then check the device settings and look at what device type is set.
I haven't tried Rules Machine - can check that out. In the device settings it is showing as a "Generic Zigbee Motion Sensor".
Under the Data tab it shows as "SmartThings" for Manufacturer and "motionv5" as model.
I'm not saying to use it to get around the issue, but if it's not showing up there either then at least you know it's an issue with the device and not the app. Sorry, but those were the only ideas I had lol. I just started migrating over last night and haven't paired anything besides light switches and contacts so far. I'm sure someone else will chime in
Yeah, it's a good suggestion - I was going to be checking out Rules Machine next anyway.
I appreciate your reply - good luck getting things set up.
Are both devices using the same 'Type (Driver)'?
I think I found the problem - it's actually registered as a moisture sensor.
I changed the device type to a motion sensor.
What I'm looking at now is my Hue bulbs - if I understand correctly, I should be able to turn them off/on under devices and clicking on one. I'm not able to turn off/on and the status = "Unknown".
Will search the forums to see if anyone else has run into this...
Edit:
I removed all my lights and the hue hub and set up again.
All of the lights are now showing "Active" but trying to turn off/on in settings doesn't do anything.
I noticed the following errors in the log:
2018-12-01 03:28:44.039 pm errorgroovy.lang.MissingMethodException: No signature of method: hueIntegration.updateBridgeStatus() is applicable for argument types: (com.hubitat.app.ChildDeviceWrapper) values: [Hue Bridge (10366B)] (ssdpBridgeHandler)
app:12018-12-01 03:28:43.065 pm errorgroovy.lang.MissingMethodException: No signature of method: hueIntegration.updateBridgeStatus() is applicable for argument types: (com.hubitat.app.ChildDeviceWrapper) values: [Hue Bridge (10366B)] (ssdpBridgeHandler)
Note I'm using a v1 hub if that matters...
I would remove the hue bridge integration (check for multiple copies) and any hueBridge* devices if they got orphaned in any way in device list (this shouldn't happen, but good to check anyway)
Then start over with the hue bridge integration, discover bridge, tap the button, discover bulbs add bulbs, click done.
Once you exit the hue bridge app completely, switch over to the device list and check for your hue bridge bulbs and test each one to make sure each works as expected.
Thanks for the suggestions. I removed the Hue Bridge and tried again a couple times. My last attempt worked. I'm not 100% sure what was different other than it took a couple presses on the Hue Hub button the time it worked.
