Hello, I have a siren, and I would like a beep when I arm or disarm, I can't find a way to do it, let's see if someone can help me
What type of siren are you using?
use this siren with your driver, € 20.85 40% DISCOUNT | NEO z-wave Plus-Home Siren Alarm Sensor, Battery Powered Wireless Device, USB Charging Also https://a.aliexpress.com/_uzZKAJ
Also typically Sirens are pretty loud, have you considered a keypad (they can have entry/exit delays programmed in HSM).
Not having that device I can only take a stab (Using Rule Machine), but this works using my aeotec gen 5 siren.
Thank you very much friend, I could not find it!
Of course, glad to be of assistance. The actuator can be tricky to find the first time you go to use it.
