Sonos Groups
After you apply a group preset how do you un group and remove a device from the active group.
Dohhh, if you dig into the app under manage group presets the is an option to dissolve and remove the group, and that's not very helpful. I'll add a device command that that breaks up the group
There is a device command to trigger the group preset but when i tried it, it didn't seem to work, then how do you use it in rules?
Ie trigger all sonos group then do something in RM. Assuming custom command, but what would the option then be
I have made groups like this with a custom rule.
{5CCE5014-3D42-4C60-B190-F8ACB81BDF1F}
The playFavorite is finicky working only sometimes. I think if it is a Sirius XM normal Channel it seems to always work but if it is a streaming channel its hit and miss.
So a string of the group name?
Yes
