Ok. So I can have two http statements to put three SONOS into a group! That's great. Is there a way to use the presets.json to achieve the same thing?
If you find one, could you share it? Many thanks!
Are you trying to speak on ALL Sonos players? The node-sonos-api also offers the "sayall" endpoint and uses it's internal TTS. It will join all the players to a group and restore the original state after the TTS was spoken.
Just an alternative.
I haven't used the presets.json, but I'll take a look at the documentation
So here is a http command that I send to node-sonos-api with a preset:
http://192.168.10.63:5005/preset/{"players":[{ "roomName": "Office", "volume": 15},{"roomName": "Outside", "volume": 25}]}
This joined the two players that I have specified there. I am sure you can also put that JSON into a preset file and call it by name. This made my Office speaker the master. Basically the first one will become the master
I just created a preset file called group.json that is stored in the preset folder and has the following content
{"players":[{ "roomName": "Office", "volume": 15},{"roomName": "Outside", "volume": 25}], "state": "stopped"}
It creates the group and also leaves it in a "stopped" state, meaning nothing is playing.
You can then send a HTTP command
and it does the grouping for you
EDIT: BTW, the presets.json is deprecated and you should use individual files in the preset folder.
My thought is that I could probably remove the Sonos app from HE if I can get a few of these things down. I'm trying to use the preset to group the speakers and then play a news feed from radio.com. I think I'm about ½ way there. I created a preset called news.json:
"players": [
"roomName": "Bedroom",
"volume": 20
"volume": 20
"roomName": "Kitchen",
"volume": 20
"favorite": "localNews"
Update: This works! Thank you @dan.t for the favorite tip. It's working great. Now I'll just put that in my RM app and then another one to pause it.
One interesting quirk is that with the player, even though the stop button is pressed, the Sonos App and the devices in HE still show them as playing.
There are a few ways to do that but in all my playing I found the following as the most reliable:
- In the Sonos App, search radio.com for the station you want to play
- Click that little arrow next to the station and add it to your Sonos favorites.
- Give it an "easy" name in your favorites. With easy I mean easy from an HTTP perspective (e.g. no blanks or special characters)
- Call the following HTTP endpoint to play the station:
http://[IP]/[ROOM]/favorite/[FAVORITENAME]
e.g.: http://192.168.10.63:5005/Office/favorite/Mix1041
This has been working flawlessly for me for months.
I think you can also call the favorite within the preset with the entry:
"favorite": "my favorite name",
but I have never tried that
I have not observed that but I only open the Sonos app to make favorites.
I use my MagicCube to control my Sonos and play/stop my favorite stations and control volume
I finally removed the Sonos App from HE. Now I have a virtual button which sends an HTTP GET http://IP_address:5005/pauseall and that stops things. I'm really loving the Node API solution. Well done.
Excuse my ignorance here but to run the "node-sonos-http-api" server you need a separate device to host it correct? Like a RSPi connected to the network somewhere?
That is correct. There has to be an external device running Node. I'm using a Mac mini.
Not sure why I didn’t get a notice about your response but thanks!! I’ll probably pick up a RPi or something.
If only Trueplay profiles were discoverable/configurable
I posted some thoughts in this thread. There is some limited info on web hooks too in the API documentation.
How would you find out which speaker is the ‘master’
Regards
Jan
Apologies for reviving this thread, but didn't want to start a new one since there's a lot of info here that's relevant to what I'm trying to do. Also, the question isn't entirely about HE, but I gather some people in this thread may have gone through a similar setup and be able to help me.
I have managed to get the sonos http api working thanks to the great info and tips in this thread.
I am now wanting to host that node.js server in a Synology NAS, for convenience. I have found versions of that api wrapped on a docker image, and it is working so far, but I have no idea where to place the presets and setting files when using a docker image.
I see I can define and mount volumes in the Synology docker app, but not sure what my mount point should be so that the sonos api can find them.
Any help or pointer is greatly appreciated.
Thanks!
I’ve mapped /app/settings.json to /mnt/user/appdata/node-sonos-http/settings/settings.json
Thanks!
I had to map /usr/src/settings.json instead, but thanks for setting me on the right track.
From there, and to avoid linking other preset files one by one, you can specify a path to your custom presets in settings.json.
"presetDir": "/path/to/presets/"
Cool, I'm going to follow your posts about NAS/docker configuration, because I have been considering moving to docker from my nodejs installation on a vanilla Raspberry Pi OS installation.
In case it is useful to anyone else, I just posted by Sonos node-sonos-http-api drivers here and added them to my HPM repo.
These drivers give a lightweight abstraction of grouping/ungrouping and album or track art for display on dashboards. They also give the ability to create custom commands for the node-sonos-http-api and expose them through numbered button pushes. I found this easier than assembling a bunch of HTTP queries in RM rules and other virtual devices.
How is the master of the group identified?
