Sonoff ZBMINI Relay (Zigbee)
Hi,
I would like to add Sonoff ZBMINI Relay (Zigbee). It is on your Device Compatibilty list. The HE sees it and I can add it. However, on the "Device information" page I cannot set the proper "Type" of the device - there is no Sonoff ZBMINI Relay on the list...
Therefore, I cannot test it. It does not work when I set it on the dashboard neither...
How to setup this device? It should have worked - it is on the compatibility list...
Kind regards,
Kris
Use the driver Generic Zigbee Switch!
Thanks a lot! :slight_smile: Work fine.
