Having trouble with SONOFF Zigbee USB Switches. Pairing with C-8, it says it pairs but does not work. Tried changing device driver from generic Zigbee to Tuya USB Switch with no luck. Any tips, tricks, or ideas?
Identical, except I am using a vanilla C8. It added the device with no issues, worked for a bit-- now it doesn't
Try to re-pair (without unpairing first) using the FULL modified DLV method, INCLUDING the part about removing the battery: [RELEASE] Tuya Zigbee Contact Sensor++ w/ healthStatus - #70 by John_Land
EDIT: ignore the statement about "removing the battery" -- I forgot that this device draws power from a USB source.
This is a zigbee communication issue - the switch has lost communication with the hub. It isn't a driver issue. @John_Land's suggestion was on the mark.
I solved the problem and it really wasn't a big mystery in the end. When I moved to a new house I decided I was going to divide up two hub with one for all the zigbee's stuff the other for all of the Z-Wave stuff. It would make it easier on me to maintain and I thought make both units faster. What I failed to do on the Z-Wave Hub was to turn off the zigbee radio. I realized that this morning and as soon as I did, my problem was solved.
Thanks to all Who provided advice, and help. In the end it is one of those things that you overlook until you go back from the start to solve the problem.
