Sonoff snzb-02wd snzb-02ld
I am looking at these devices for refrigerator / freezer temperature sensing and curious if anyone has tried to pair and use them yet?
The 02WD looks very interesting, and I would certainly look at it for the same purpose. What I have now burns batteries too quickly, and I'm hopeful this would give me a longer battery life (being that it's rated for colder temperatures and humid environments).
Not sure about Hubitat support? Hopefully some community driver would support, otherwise may be a "Buy & Test" type of situation. Also, seems they're not available on Amazon in USA, and only available via itead.cc with a longer delivery timeframe.
This driver will most likely work, and also give you advance preferences for setting the reporting frequency,
I have the probe version. I've only had it a couple of days but so far it's been working great. I'm using the driver posted above.
I picked up the 02WD, and using the Tuya driver - all seems to be good.
When I use the above driver for a wd model it acts like it isn’t taking the configuration.
If I use the built in sonoff temperature humidity driver I get battery, temperature, and humidity. In the device the temperature shows in F, but on the device it shows C and I don’t see a place to change that.
With that driver - I haven't been able to get it to adjust the settings for only update on a Temperature Change of x Degrees, etc. Have you? If so, do you have the Driver on "Auto Detect" or on a specific attribute?
use a PIN double press the device reset button
+1 for this driver with the SNZB-02LD Probe version.
+1 on the SNZB-02LD Temp sensor for an old fridge I'm afraid will give out without me knowing. Used the driver referenced as well and left it on autoselect. [RELEASE] Tuya Temperature Humidity Illuminance LCD Display with a Clock (w/ healthStatus)
